I have a DVI and VGA connector, also HDMI on the MB. The two ACER LCD has DVI and VGA but don't work with DVI connectors/cable.
Any idea what needs to be done or how to set it up?
The graphics card don't see the DVI monitor.
I tested the monitors with another card with two DVI and it works with a VGA conversion.
Appreaciate your assistance
	Thread moved,check to see if there is a button on the monitor to switch from vga to dvi. I think,therefore i am a hamster.
	Thanks.. the monitor has a selection from Analog to digital, but don't like the digital selection. It's not the right signal.
 Maybe the graphics card or the cable?
	I am sure it is the monitor. I have a acer S230HL monitor and it works fine with VGA, but the DVI has gone south. Not even a year old. I changed the cords and nothing but sure enough, it worked hooked up to my Visio tv. The display converter or something rather has gone bad. Before finding this out, I have updated my BIOS, I have reinstalled windows 7, and reinstalled video drivers and none of that helped. I laughed when ever I seen someone comment on going into the BIOS to set video display to HDMI/DVI really? and these are computer geniuses on the internet.
	One monitor, no signal, maybe monitor broken, but two monitors, neither working using DVI?
 Not that I have an answer, but given you have two monitors of the same brand and neither work using DVI, it seems more like it'd be a communication problem to me.
  LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 17:20
  Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31
  DVi to VGA adapter for acer lcd questionBy Denvers Dawgs in forum ComputerReplies: 4Last Post: 2nd Feb 2011, 14:24
  Monitor DVI Port not Working for ComputerBy wulf109 in forum ComputerReplies: 5Last Post: 27th Oct 2009, 17:54
  acer monitor will not let me adjust screen positionBy vhsreject in forum Media Center PC / MediaCentersReplies: 1Last Post: 7th Feb 2009, 03:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
