Results 1 to 9 of 9
  1. TheNero
    Jul 2011
    Philippines
    From this point while I was away.. I have encountered video files that is over 200MB (297MB to be exact) in size.
    Which has a very good quality.. Can this be possible with .avi (xvid)?
    Because the file type is Matroska (.mkv)
    I will edit this post to add the "Media Info"
    If anyone knows how to achieve this.. Please share or make a long/short tutorial. It will be greatly appreciated by anyone whoever comes by it.
  2. Originally Posted by NeroLi8gerzid View Post
    You currently haven't stated the running time of this video.
    (Personally, I have a 1 minute HD video which is 60MB - excellent quality it is too).
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Your post topic says "retains the original quality".....that is IMPOSSIBLE. You can make some very nice looking video(compared to the original) with H264/X264.
  4. MKV and AVI are containers. You can put video encoded with the same codecs in either container. So yes, you can have the same quality and file size with MKV and AVI.
    But if you need to use Xvid, and your MKV file uses a better codec like x264, then no, you can't have the same quality at the same size.
  5. TheNero
    Jul 2011
    Philippines
    For the time being.. I'm downloading the movie again..
    Here is what I can see..
    Type : DVDRip
    Length : 1:34:43 (h : mm : ss)
    File Size : 297mb
    Format : matroska
    Resolution : 704x400
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Buy the DVD and you'll get perfect quality.
  7. TheNero
    Jul 2011
    Philippines
    DVD = 4GB
    Here's a question for you.. Since you aren't helping much.
    Do you know the main reason why I want or why people want low file size movies?
    At any rate.. I have the media info now..
    Here it is! (Check attachment)
    *Edit added Screenshots*
  8. Originally Posted by NeroLi8gerzid View Post
    Hech54 was alluding to the fact that discussing downloading copyrighted material is generally not allowed here. Personally I don't care. If you want similar results use an h.264 encoder. Xvid (MPEG 4 Part 2, ASP) cannot compress as well as h.264 (MPEG 4 part 10, AVC).
  9. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Let me guess, to put on a tablet or phone?
    http://www.kiva.org/about
