Im trying to author yet another DVB TS file to Bluray this time using EasyBD Lite, but it is not accepting the .264 file after I demux from the DVB TS. Spits out an error saying "Unknown format" but it accepts the audio ok which is ac3.
I'll explain my set up and the specific video info.
Im using a Vu+Duo HD sat receiver to record a DVBS2 TS stream. (very similar unit to the dreambox).
First thing I do is demux the raw TS file with "DGAVCDec" to get the video/audio to seperate files.
The video format is full HD h264 1920x1080 interlaced 25fps top field first.
Audio is either ac3 or mp2 depeding on the TV channel I record from, if its mp2 I convert it to ac3 anyway.
Next I add the .264 and .ac3 files to EasyBD Lite and try to compile. This is where I get the "unknown format" on the video stream.
I used to use tsmuxer gui to do this, and it did work some of the time, however I got a lot of m2ts files which were out of sync towards the end of the file so basically gave up.
It might be that your avc streams are not compliant
I would ask the developer who replies regularly at Doom9 forum
http://forum.doom9.org/showthread.php?t=160682 -
Thanks, unfortunately I wont be able to get any sort of help there untill after 5 days. As I cannot post or reply there untill after 5days of registration. Its sad when forum admins operate this way. I can understand it though as a spam prevention measure, but 5days is a bit extreme in my opinion.
In the mean time I have uploaded a sample TS file here:
http://www.megaupload.com/?d=M35W44WT
It would be much appreciated if someone with access to doom9 could alert user "DVD Logic" to this thread.
Many thanks.
Accepting a Live Video Stream as input
By jay.kert in forum Video Streaming DownloadingReplies: 0Last Post: 22nd Oct 2011, 14:31 -
Convert DVB-T MPEG4 H264 stream
By rocka in forum DVB / IPTVReplies: 14Last Post: 5th Aug 2010, 06:12 -
Stream DVB-S to media centers
By sal88 in forum DVB / IPTVReplies: 2Last Post: 31st Dec 2009, 12:03 -
how to download the transport stream from dvb receivers like SA z65
By phpmysql348 in forum DVB / IPTVReplies: 2Last Post: 4th Oct 2008, 13:20 -
DVB MPEG2 544X480 convert to H.264 - Any clean work flows?
By Raycaster in forum Video ConversionReplies: 0Last Post: 18th Jul 2007, 09:57
