I have been looking for a BluRay drive for my PC but they are still a bit too expensive for me. I got the idea of buying a BluRay player (I can get a used one for about $25) and taking out the drive from the player, and hooking it up to my PC via a SATA/IDE interface. Is this possible? I've never opened a standalone BD player before. Do the standalones just basically use OEM BD drives, like the ones they sell for PC's?
not usually, the drive most likely is completely bare with no metal box around it. no way to mount it in a pc.
Thanks for the reply, but I don't need to mount it. I have an external USB converter, which can hook up to any SATA or IDE hard disk drive or regular DVD-ROM player.
I just want to know if the drive inside stand-alone BluRay players are the same ones they sell for PC's, or are at least compatible to be used in a PC? -
Umm...."no metal box around it" means no connections(like SATA) that computers have. Just wires from the drive to a circuit board.
Probably it will have an IDE or SATA plug. I opened up an old DVD recorder and found that did anyway.
I could put the drive into a PC but the problem is that I couldn't get proper drivers for it. It was recognised as a DVD burner but there was no way to even eject the tray by software or hardware. (No physical eject button either.) So I just junked it.
But you might be lucky and find it compatible with a standard drive. -
Well I suppose for $25 I might just take the chance. In the worse case, I could just use it as a stand-alone BluRay player. Thanks for the advice.
BD read/DVD burners are $59.99 at the egg, with one BD burner for $10 more with rebate.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
External Hard Drive to Bluray Player to Receiver to TV Problem :)
By LBSTEVE in forum AudioReplies: 1Last Post: 18th Jan 2012, 23:00 -
How to play HD Video from Hard Drive to Bluray
By jbitakis in forum Authoring (Blu-ray)Replies: 51Last Post: 14th Nov 2011, 16:43 -
Remove drive from BluRay player?
By satviewer2000 in forum Blu-ray RippingReplies: 2Last Post: 5th Oct 2011, 02:03 -
.mkv files on tv from Hard Drive through Bluray player to TV?
By xxnonamexx in forum Portable VideoReplies: 10Last Post: 7th May 2010, 12:00 -
Is using a Bluray drive better than a regular DVD drive?
By imfallen_angel in forum DVD RippingReplies: 14Last Post: 20th Mar 2010, 21:49
