What would make the xbox 360 play some mp4s and not all? I have two different files on my external hard drive, and the xbox will play one but not the other. The only thing I can think of is using an app(?) to see what is different in the two, conversion wise. Has anyone ran into this issue before? Thanks!
Well, gosh golly gee whiz, you might take a look at the possible encoding parameters for an mp4 file, and then take a look at the specific requirements for an mp4 that the xbox can play, and you will notice that the xbox set is a much more narrowly defined group.
It is NOT an mp4 player, it is a player that can play Some mp4 but Not others. Very much like a lot of DVD players that can play Xvid or Divx, IF they are encoded with specific settings. Also similar to the MPG files a dvd player can handle, it is by no means ALL mpg files.
You apparently have one mp4 in the SOME group and one mp4 in the OTHER group. -
Simple MKV to MP4 Conversion Guide (Xbox360)
By Cloud101 in forum User guidesReplies: 35Last Post: 8th Nov 2011, 17:41 -
MP4 with 2.0 audio: the only HD format compatible with BOTH ps3/xbox360?
By Randm in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2010, 14:09 -
H264 to MP4 for PS3 or XBOX360
By DVDONE in forum Video ConversionReplies: 4Last Post: 27th Mar 2010, 16:07 -
Questions about MP4 Xbox360 conversion
By trooper11 in forum Video ConversionReplies: 6Last Post: 15th Mar 2008, 15:40 -
mkv to xbox360 compliant .mp4
By wallace4793 in forum Video ConversionReplies: 1Last Post: 26th Jun 2007, 15:13
