Hi,
this is what I do:
1. demux original ts into audio (ac3) and video (264)
2. open audio with avisynth:ffmpeg -i input.ts -acodec copy audio.ac3 -vcodec copy -f h264 video.264
3. mux back into ts:Code:LoadPlugin("NicAudio.dll") V = BlankClip(height=576, width=720, fps=25) A = NicAC3Source("audio.ac3") A = A.FadeIn(50) A = A.FadeOut(50) AudioDub(V, A)
and I have only couple of seconds of audio in my output file.ffmpeg -i video -i avs -vcodec copy -acodec ac3 -ac 6 -ar 48000 -ab 448k -f mpegts -y output.ts -map 0.0 -map 1.1
What should I change in avs to have full lenght audio after muxing.
Thanks.
Results 1 to 10 of 10
BlankClip by default gives a length of only 10 seconds.
The simplest solution is to make the avs deliver audio only:
Code:LoadPlugin("NicAudio.dll") NicAC3Source("audio.ac3") KillVideo() # kill dummy video from NicAC3Source FadeIO(50, fps=25)
@Gavino
Thanks, that worked.
@manono
I just wanted to make "one click solution" for fading audio (without help of audacity)
Just have one more question:
how to change 1st frame of 264 video into IDR frame - when I cut (beginning) in VRD on standard I frame than it stays as I frame - if I cut on P or B frame it gets converted to IDR.
I'm asking since I've noticed that mplayer doesn't play any TS with 264 inside which doesn't start at IDR. -
It has to be encoded that way in the first place, or you re-encode it. You can force an IDR frame in x264 by using a qpfile
http://mewiki.project357.com/wiki/X264_Settings#qpfile -
You have to re-encode the GOP. There is no way around it. You can't just change the frametype
When you cut just before P or B frames with videoredo it gets converted to IDR because the entire GOP is re-encoded. It becomes a reference for the new GOP.
How did you expect it to work differently ? -
Yes, that is true - you just misundertsood me - I know that entire GOP must be re-encoded while cutting on P, B-frames and there must be new IDR at beginning.
But what if I cut on I-frames that are not IDR (I'm talking about I-frames inside GOP) then there is no need to re-encode (rebuilt) entitre GOP? - to me it looks so because VRD doesn't convert such frame into IDR - that's what I asked on VRD forum.
Sorry for such questions but I'm still a newb here. -
I just got a reply on VRD forum:
If you cut on an I frame or IDR there is no recoding so the frames remain unchanged(if) on a B/P frame - VRD forces a recode of that scene and starts with an IDR
But I found another program called smart cutter where if cut is done on i-frame (non IDR) this frame is being converted into IDR so as you say entire GOP is re-encoded.
Thanks.
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 12:45 -
how to get audio/video AVI from Avisynth?
By spiritgumm in forum Newbie / General discussionsReplies: 10Last Post: 12th Jun 2010, 18:24 -
VDM or AviSynth: audio fade in/out
By hollowman in forum Newbie / General discussionsReplies: 5Last Post: 27th Aug 2008, 08:05 -
how can I add "Fade in / Fade out" effect in my video clips
By mb508 in forum EditingReplies: 5Last Post: 9th Jul 2007, 16:02 -
Fade-in\Fade-out filter, VirtualDub MOD
By GangstaRap in forum Video ConversionReplies: 3Last Post: 21st May 2007, 20:58
