Lagarith and CS 5.5 et. al?
I'm starting to use CS 5.5 in earnest and am confused about how to export the entire timeline as a Lagarith AVI and what settings it takes to get it done as it should be. I'm using the 64-bit version on Windows 7.
My goals with Lagarith are twofold: back-up project as lossless but more importantly in order to create a AVI file which is part of the process when converting HDV programs to SD.
Let's fast forward to Adobe media encoder video tab!
1) For the purposes stated above, should I check off the "Prevent upsampling when decoding" or not? what ramifications does that have?
2) Should I choose YUY2 or YV12 for colorspace? What's better for Premiere encoding to MPEG-2 DVD after it gets converted/downscaled elsewhere to SD?
3) Now for the kicker. The aspect ratio for HDV source material is typically set to 1440 by 1080. When manually typing in either one of those dimensions it automatically comes up with the other as "wrong".
a) When I type in 1440 it gives me 1440 by 960.
b) When I type in 1080 it gives me 1620 by 1080.
There's no obvious way of getting around it.
Is there a square versus non square pixel issue here?
I don't want areas of black displayed when viewing the projected output file when the entire screen should be filled and 16:9.
Please lead me along the path here to a solution. How to I get 1440 by 1080?
4) Lastly, what does frame blending do? When should it be selected or left un-ticked? Does it make an important visual difference?
Thanks in advance for contributions to my growing CS 5.5 knowledgebase.
Results 1 to 9 of 9
This is what the homepage says
http://lags.leetcode.net/codec.html
Checking this option and having the mode set to RGB or RGBA will prevent Lagarith from performing any colorspace conversions when encoding or decoding video.YUY2 or RGB . Interlaced YV12 is problematic2) Should I choose YUY2 or YV12 for colorspace? What's better for Premiere encoding to MPEG-2 DVD after it gets converted/downscaled elsewhere to SD?
If you are coming out of Premiere and have used filters like color correction, you will be in RGB, and should use RGB for everything until final delivery
RGB takes more bandwidth than YUY2 . RGB is not subsampled 4:4:4, YUY2 is Y'CbCr with 4:2:2 subsampling
Things like graphics, titles are RGB overlays. They will be more sharp and crisp compared to YUY2
Unfortunately DVD is YV12 4:2:0 subsampled. Each colorspace conversion causes some quality loss (even with a lossless format like lagarith) - the point is to reduce the number of uncessarly conversions
I don't have it open right now, but I think you set the PAR Pixel Aspect Ratio to 1.333 then enter 1440 x1080 in the dimensions. HDV uses NON square pixels, upper field first. If it's still not working , uncheckmark the chain link icon that constrains options3) Now for the kicker. The aspect ratio for HDV source material is typically set to 1440 by 1080. When manually typing in either one of those dimensions it automatically comes up with the other as "wrong".
It does nothing unless you have speed changes or use deinterlacing.4) Lastly, what does frame blending do? When should it be selected or left un-ticked? Does it make an important visual difference?
Frame blend off means frames are duplicated for speed changes instead of blended mix. Same with deinterlacing, blend = blend deinterlace. Blend off means cubic deinterlace. -
Update:
Sorry, I need to catch up as you are most helpful by relaying crucial information which is a vital part of a solution.
Wed + Thursday I was on out of state on a 2 day trip and had no capability to further this discusssion.
Friday (today) am scheduled to go on another trip returning home about mid next week.
Please bear ne as I find your assistance and advice to be extremely vauable!
I'll be in touch as soon as achievable.
Thanks so much -
Thanks for the addtional information and for clear answers provided.
I spent most of the last week out of state and am now resuming this mission. -
I fail to see why Lagarith codec* should be used with Premiere Pro except for possible archive after the job is done. For post production use a tuned codec (Cineform, Avid dnxhd, AIC, ProRes422). HDV is an alt.
*Lagarith is for deep freeze archive, not for high performance editing.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
It's ok edDV,
I usually keep all of a project assets and master timelines stored on an external HD just in case I need to resurrect and re-assemble a project in the future!
How do I free up my PC while Prem Pro is rendering?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 12Last Post: 30th Oct 2011, 19:54 -
Cineform Neoscene and Prem Pro CS3.2 questions/Quest
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 33Last Post: 4th Sep 2011, 22:04 -
Need help finding the right CS5 Prem Pro PC. Please help.
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 1st Apr 2011, 11:50 -
Prem Pro CS export movie function: What are the optimal seetings?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2011, 19:47 -
Best way to archive HDV material using Prem Pro CS3?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2010, 16:29
