Ok this is quite weird.
My camera which is a nikon D5000 is the only HDMI device we have at the moment. I have a digitally downloaded movie in my computer which i want to see on TV.
the camera captures in .avi format, but when i convert to avi using AVS the camera gives an error saying no image file available.
please help thank you \
Use mediainfo to compare ALL settings like video codec, audio codec, frame size, etc in the nikon avi file. Then convert to as similar format with software like xmedia recode, avidemux, freemake video converter or avs as you use.
If you already did that then post the mediainfo details from your nikon avi file. -
You cannot put non-Nikon images/movies back on to a card and have the Nikon be able to see it. Most Nikons record in MJPEG.
took a random file from transfer folder
General
Complete name : C:\Users\*****\Pictures\Nikon Transfer\030\DSC_0255.AVI
Format : AVI
File size : 59.3 MiB
Duration : 1mn 17s
Overall bit rate : 6 465 Kbps
Video
Format : JPEG
Codec ID : MJPG
Duration : 1mn 17s
Bit rate : 6 283 Kbps
Width : 640 pixels
Height : 424 pixels
Display aspect ratio : 3:2
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.965
Stream size : 57.7 MiB (97%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 1mn 17s
Bit rate mode : Constant
Bit rate : 176.4 Kbps
Channel(s) : 1 channel
Sampling rate : 11.025 KHz
Bit depth : 16 bits
Stream size : 1.62 MiB (3%)
Interleave, duration : 1000 ms (24.00 video frames)
Interleave, preload duration : 1000 msLast edited by mo_yi; 4th Oct 2011 at 12:24. Reason: added data
You've answered your own question. Convert to AVI with MJPEG video and PCM audio -- with the properties similar to those in the MediaInfo listing. VirtualDub should be able do that if you get an MJPG codec. ffdshow has one. Pic Video MJPEG codec is a commercial version.
AKA a waste of time
http://www.kiva.org/about
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:40 -
MOV format from video camera>avidemux>mp4 out of sync
By duhmez in forum Video ConversionReplies: 2Last Post: 7th Apr 2011, 21:36 -
Unable to decompress your camera's image format cause a suitable codec is m
By cfairon in forum MacReplies: 2Last Post: 17th Jan 2011, 10:37 -
Convert AVI from digital camera to what format
By hemang in forum Video ConversionReplies: 14Last Post: 24th May 2008, 08:13 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
