Results 1 to 1 of 1
  1. Hi there,
    A few days ago I changed my old PC to a new one, an I3 3.1 GHZ Sandy Bridge with 4GB DDR3 1333 Mhz and a RadeonHD6450 video card.. running on Windows 7 64bit
    I usually use VirtualDub + Avisynth + CCCP for my encodes..
    but sadly, on 64bit not everything works..
    so.. I started to work with MeGUI, At first i didn't get it at all, but i managed to learn..
    Today i wanted to do a test video and everything is ok.. i have video, i have audio, but i don't have any subs and i clearly put them on video
    look at the avs script i created with MeGUI tool, AVS Script Creator:
    PHP Code:
    DirectShowSource("D:\Torrents\test-video.mp4", fps=23.976, audio=false, convertfps=true).AssumeFPS(24000,1001)
    #deinterlace
    #crop
    LanczosResize(848,480) # Lanczos (Sharp)
    #denoise
    LoadPlugin("D:\MeGUI_2050_x86\tools\avisynth_plugin\VSFilter.dll")
    TextSub("D:\Torrents\subtitle.ass")
    ConvertToYV12()
    i don't know if the problem is in my codecs or in the program...
    p.s i used this tutorial ... Hardsub Into MP4 Using MeGui - YouTube
    edit: it seems the problem was with the VSFilter from the tools folder.. i changed that with another one and now it works
    hihihi .. maybe someone who has the same problem will see this post
