Hi,
I'm experiencing occasional artifact issues when reencoding VP6 flv files. The artifacts seem to occur on the 'active' bits in the video, i.e. the elements that are stored in the keyframes (e.g. backgrounds) are unaffected.
More specifically, I'm using the VP6 6.4.2 VFW codec in VirtualDub, set to VP62 (Heightened Sharpness Profile) using these settings. I didn't touch any advanced settings. I'm using two passes of which the second one is "Best Quality". Finally, I also have a rotate filter enabled and I'm using Smart Rendering (to be able to join the videos with the ones that weren't reencoded).
Here's some info about the video:
Code:Video ID : 0 Format : VP6 Format profile : Heightened Sharpness Codec ID : VP6F Codec ID/Hint : On2 Duration : 1mn 18s Bit rate : 403 Kbps Width : 512 pixels Height : 288 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Bits/(Pixel*Frame) : 0.109 Stream size : 3.75 MiB (99%)
use a higher bitrate or better compression. VP6 was notorious for keyframe popping where you would get pixellation ("keyframes" as in I-frame)
I'll try a higher bitrate. Unfortunately I must use the VP6 compression, since I'm using the smart rendering method to split the videos, i.e. the reencoded files must be able to join with the original/not-reencoded files. It's pretty bad though. You'd think such ugly artifacts wouldn't occur at all! :P
Alright, I narrowed it down to the problem. It seems that if you higher the sharpness (only available in the profile I use) to about 8, on a scale of 1 to 10, the artifacts become noticeable. It's seems quite random but true :P
Codec Conflicting Issues
By ohnoeee in forum Newbie / General discussionsReplies: 18Last Post: 7th Apr 2011, 11:47 -
problem with vp6 codec
By Szymus in forum Video ConversionReplies: 2Last Post: 23rd Mar 2011, 06:27 -
Youtube post-upload Artifact issues
By DUCKVILLELOL in forum Newbie / General discussionsReplies: 8Last Post: 22nd Nov 2010, 01:10 -
Good Program / codec to encode Flash Vp6 files to avi? Audio is Out of Sync
By hypnoticpimp in forum Video Streaming DownloadingReplies: 1Last Post: 14th Jul 2008, 00:25 -
Video codec VP6/7
By cheerful in forum Software PlayingReplies: 2Last Post: 11th Sep 2007, 18:09
