Hello,
I'd like to replace my DVD player and am looking for an inexpensive model with a USB socket that can be used for DivX playback. Can someone please recommend a player as follows...
It's doesn't need to be Blueray just capable of playing all types of single layer writable DVD.
With the USB socket I'd like to be able to connect a 512GB hard drive, containing DivX/Xvid files, which I understand will probably need to be formatted as FAT32.
It would be nice to be able to play a DVD that have been backed up to the hard drive, by just selecting the VIDEO_TS folder, but I understand it's unlikely I'll find a player to support that.
Needless to say I'd like the player to be region free, or a hack available, and native PAL with NTSC support.
Thanks![]()
Philips DVP3560! Does all that and the upscaling to HD is excellent. I play many DVIX & XVID from a thumb drive in the USB input that look great on my 40" flatscreen. I play classic films to new films & they all look terrific. And the best part is I paid less then $40.00 for it. What a bargin.
I second the recommendation for the DVP3560. The hack listed here still works. Follow the Feb. 2011 instructions as they are a bit clearer.
https://www.videohelp.com/dvdhacks/philips-dvp3560/10922
Note that if you install any firmware updates that they may break the hack. -
It's a couple of years old now, but my Pioneer DV400V has a USB port, plays DivX and as an added bonus, plays discs from all regions!
Recommend Blu-ray / DivX Certified player
By culttvguy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 16th Feb 2012, 08:24 -
building an htpc vs divx dvd player w/ usb
By munozsblazer in forum Media Center PC / MediaCentersReplies: 21Last Post: 30th Jan 2008, 01:26 -
HD DIVX DVD player with USB?
By Raptor16 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 30th Oct 2007, 12:12 -
Budget DVD player with DivX, upcovnerting & USB
By cheerful in forum DVD & Blu-ray PlayersReplies: 1Last Post: 29th May 2007, 11:24 -
Hack to convert USB/DIVX DVD player to read from the Network
By thrutnut in forum DVD & Blu-ray PlayersReplies: 8Last Post: 21st May 2007, 11:27
