hi people,
not sure where this one should go so i am putting it here.
was wondering how come it seems that when i play my captures on my dvd player the ratio looks biger than the source?
depends on alot .... what was it captured at ( 480X480? .. 4:3 16:9 ? ) and what software you used to go from a capture to a playable cd-r/dvd-r
i captured at 352X240, then converted to mpeg1 using tmpgenc, using the vd template, the ratio was 4:3.
the video just seemed bigger than it should, i know it should be big cause i have a 32" tv, but it just didn't look right.
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Freeware App To Change Video File Size, But Not Video Or Audio Codecs
By LouieChuckyMerry in forum Video ConversionReplies: 4Last Post: 19th Jun 2010, 09:06 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14 -
How should I size my video?
By vid83 in forum Video Streaming DownloadingReplies: 12Last Post: 30th Nov 2008, 03:34 -
Video Size
By sullins in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2008, 17:34
