  1. TheNero
    Jul 2011
    Philippines
    ok.. So here.. I added subs using an .avs and it works! But.. The output file is too large.
    Input - 1.6GB
    Output - 3.63GB
    Here's what I did..
    1. Dragged the .avs file into VDubMod
    2. Compression -> Xvid (Xvid Home) -> Two pass - 1st pass (Target kbytes/bitrate is dashed out)
    3. File -> Save as -> (Checked the "Don't this job now;add to job control") -> Save
    4. Compression -> Xvid (Xvid home) -> Two pass - 2nd pass (Target kbytes I placed is 718000 and not bitrate)
    5. (Repeated Step 3)
    6. Job Control -> Clicked start
    Result
    First Job - 3.2GB .avi with no video just audio
    Second Job - 3.63GB .avi with video and audio
    2 files that is more than 6GB in total
    Did I do something wrong? Or did I miss something..
    I wanted my 1:33:00 movie to be about 700MB.. So it would fit in a disc.
    If someone could teach me the right way to get my 700MB movie file. (With screenshots or proper and detailed instruction)
    Would be greatly appreciated..
    I'm using Xvid 1.3.2
    Mar 2008
    Is it possible that you created a file with uncompressed audio?
    Use Mediainfo to check the video/audio bitrates of your created files
    Use the calculator on the xvid config box to find the proper bitrate/size, it takes into account the audio..
  3. TheNero
    Jul 2011
    Philippines
    Thanks mate!!
