Hi all,
How can i extract audio tracks from avi file. Could you tell me the source code to do it?
Thanks!
Not much help unless you would tell us what kind of 'AVI'. That's just a generic name, not the actual codec used. There are dozens of AVI formats. Drop it into MediaInfo, tree format, or use a similar program and post the results.
Just generically, you could try dropping the file into VirtualDub or maybe AVIDemux and demux the audio from the video. That would get you a separate audio file. There could be a bit more too it, but that will likely get you started.
And welcome to our forums.
How to demux .avi file with multiple audio tracks?
By junglemike in forum AudioReplies: 8Last Post: 26th Oct 2012, 19:05 -
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 06:26 -
AVI File - 2 Audio tracks
By iSorrento in forum AudioReplies: 9Last Post: 7th Apr 2008, 18:48 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40 -
Creating an .avi file form a .mp4 file
By Seagrass in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2007, 04:47
