Is there such a thing?
if anyone can please helppppppppppppp
this is the best method I found for this difficult conversion:
How to convert ASF/WMV files to AVI.
OK, first let me say that this method is a bit of a pain in the butt, is not user friendly, and does require that you have the registered version of at least one program. Having said that, this method will allow you to make a flawless( as much as possible ) conversion from an asf/wmv directly to avi even if the file is encoded with the WMV1 or WMV2 codec.
First we'll start with what you'll need.
1)GraphEdit : get it here http://www.dvd-digest.net/downloads/files/encode/graphedit.zip
2)Imedia AVI_renderer : http://www.divx-digest.com/software/mpeg2avi_imedia.html
3)AsfTools : www.geocities.com/myasftools/
4)A video to work with, for this example I'll use the movie trailer of Black Hawk Down. I used StreamBoxVCR and downloaded it from here mms://agency2wm.fplive.net/agency/2/2/film/blackhawkdown/trailer_2/bhd_trailer2_300k.asf
5)Registered version of MotionPerfect : http://www.motionperfect.com/
OR YOU COULD GET THEM AT THIS YAHOO GROUP (and any necessary patches) http://groups.yahoo.com/group/buzzinhornetz2002_2/files
First we're going to need to get some essential information from the asf file. Namely, the frame rate and the number of frames in the file. Open your downloaded file in asftools and click on the Advanced button. Click on the "Convert to AVI" tab, make sure timing method is set to Minimum extra frames, and click on Convert. When the conversion is finished, note the "frame rate" which can be read at the field: "Frame/Sec".
and number of frames in asf/wmv file which is: (Total frames shown in message window) minus (number of frames added for sync. also shown in message window)
Our example has 4491 frames and runs at 29.966fps. You can now delete the avi file.
Before we go any further, you will need to have a registered version Motion Perfect installed, and you will need to install the AVI_renderer filter. You should have downloaded a file called i-media_mpeg2avi.zip, in this zip is a file called AVI_Renderer.ax, extract it to the directory of your choice, just rember where you extracted it to. Now click on Start->Run, in the box type in regsvr32 and then the path to AVI_Renderer.ax in quotes. So, if you extracted it to c:\filters, you should type in : regsvr32 "c:\filters\AVI_Renderer.ax" . Click OK and you should get a message that the filter registation succeded.
Now we are ready to build our filter graph and start out conversion. Open GraphEdit, click on File->Render Media File, and select your downloaded asf file ( bhd_trailer2_300k.asf in our example ). Once the file is loaded, you will see the filter graph that GraphEdit created. Delete both the Video Renderer, and Default Directsound Device filters. Next, click on Graph->Insert Filters, when the window comes up, expand the DirectShow Filters category. Add a Mediamend ( you will not see this if you do not have motion perfect installed ) filter and an I-Media AVI Renderer filter. In the dialog that appears choose custom for frame rate. To get a frame rate of 29.966fps set the rate to 29966 and the scale to 1000. Click OK then choose an output file name. Now Right-click on the Mediamend filter and select properties, set playback time to 1, set frame rate to 29.966 and set interpolation mode to 0. Now connect the output of Windows Media Video Decoder to the Mediamend filter. Connect the Mediamend filter to the video input of the AVI_Renderer. Connect the Windows Media Audio Decoder to the Audio input of the AVI_Renderer. Check the Show frames box on the AVI_Renderer window. Finally press the play button on the toolbar. A dialog will appear letting you choose the codec you want to use. Your AVI should now be encoding. Once you see in the AVI_Renderer status box that your video is done encoding close graphedit.
You're done. Yeah. You should now be able to play your new avi file.
Just a couple of final word here: When VirtualDub 2 is released, this will probably all be a mute point in that VirtualDub 2 will be DirectShow based and should therefore be able to open and convert asf/wmv files natively. Also I should point out that there are probably several other methods for doing this with GraphEdit. This is just my method. It works for me.
by CHICKEN SCROTUM
edited by BUZZINHORNETS -
i'm having the exact same problem here and i tried every method i could find, including the one posted above and three step thing i found somewhere else in the forum... but i am not able to load the f***ing file... it's a streaming concert i downloaded with streambox_vcr, it's wmv1 and in the properties tab it states it is only valid the next 2 days - that's why i want to convert it... is there any way to get around that? i'm running xp, if that may be of any importance. all codecs installed, like nimo pack, newest divx, intel i236 and so on...
any ideas...? please!!!
WebEx WMV to AVI or MPG
By jgq85 in forum Video ConversionReplies: 3Last Post: 19th Dec 2011, 10:57 -
WMV and MPG to Xvid or MPG2?
By videohalp in forum Video ConversionReplies: 2Last Post: 28th Sep 2008, 00:16 -
WMV/MPG problems
By Metallian MetalGod in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2008, 22:35 -
.flv to .wmv or wmv. to mpg
By LITEONDVD in forum Video ConversionReplies: 5Last Post: 29th Jul 2007, 19:02 -
Converting WMV to MPG
By Datahead in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2007, 15:08
