in virtualdub, now I have heard there's a problem with this when I searched it, but I couldn't understand what caused the problem. can someone explain if it's virtualdub specific or if it's something else?
AnonymousGuest
9 times out of 10, the few times I've had "sync issues" in editing programs it was caused by the source material.
AnonymousGuest
source materiel have no sync issue. I encoded the same video with cbr and every thing was fine.
There is a way to fix it. Open the converted avi. Set video and audio to direct stream copy.
File / save wav.
When the file is saved, modify the extension to mp3.
Audio/audio from another file (select the mp3)
file/save as avi (save as a new avi)
This problem occurs because Virtualdub writes standard CBR headers the first time the avi is created.
It does this because it doesn't know that you chose ABR in the audio encoder settings and defaults to CBR header.
However, the process above detects the vbr/abr and adjusts accordingly.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MP2 audio with LAME?
By RogerTango in forum AudioReplies: 7Last Post: 3rd Nov 2009, 23:28 -
Joining abr vbr cbr audio videos (maybe cut/paste too)
By ZZen in forum EditingReplies: 2Last Post: 29th Jun 2009, 09:26 -
VBR, ABR and CBR ??
By moiz in forum AudioReplies: 11Last Post: 19th Oct 2008, 18:22 -
avi with ABR/VBR
By LittleJimmy in forum Newbie / General discussionsReplies: 7Last Post: 14th Feb 2008, 18:08
