I'm trying to compress a 2 hour movie into 2-3 seconds to make a kind of quick time shift effect. I use premiere but it doesn't allow me to go under certain % and I would like to produce a standalone lossless clip anyway.
What software can achieve these kind of effect?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 12 of 12
take 60 random pictures and make a video. it will look like any movie compressed to your request.
You'll also need ChangeFPS() because no player will play a video at 100,000 fps.
And at 24 or 30 fps, with every frame from unrelated shots of the video, you won't be able to tell what's going on. You need to display every frame for 1/10 second or more to really be able to perceive it. -
Is this some sort of DOS command line or something? I can't get what it is. I was looking into a more simple solution in software, the most complex tool I have is vdub, although I'm a bit more used to it, I just don't know it by hart. The closest solution I've been is to go in video /FrameRate and rate fps to around 300 and convert to 300fps, it partially worked but the file is too heavy and unplayable in players (but I can edit it).
Thanks for the suggestions again -
You might try 'Decimate by' in VirtualDub. That will at least cut down the size of the file. You shouldn't need every frame displayed anyhow to achieve your desired effect.
Try a large number like 60, then save the file in 'Direct stream copy'. Load that back into VD and change the frame rate back to the original fps and see how that looks. -
It can be done in a single step in VirtualDub. For example, in a 2 hour 29.97 fps movie, in the Frame Rate controls:
In the "Source Rate Adjustment" box enable "Change Frame Rate To []" and set the rate to 100000 (or some other big number that will give the running time you want).
In the "Frame Rate Conversion" box select "Convert To FPS" and the original frame rate (or whatever you want).
That will make the 2 hour video run for about 2 seconds. How did I come up with 100000 fps? A two hour movie has a running time of 7200 seconds (60 seconds per minute * 60 minutes per hour * 2 hours) . At 30 fps that's 216000 frames. To play that number of frames in 2 seconds requires 108000 fps. -
I used a later episode because it was on my computer (an episode I watched recently). I could tell you used Vegas because of the frame blending. VirtualDub uses simple decimation. Attached is an example for the OP.
First time caller - Captured analogue video - compression issues
By foggys916 in forum CapturingReplies: 4Last Post: 19th Sep 2011, 05:33 -
Trying to make a time-lapse video (speeding up original footage): How?
By maskingtape in forum EditingReplies: 30Last Post: 15th Jul 2010, 23:39 -
Make video from two videos at the same time
By Dr_Asik in forum Newbie / General discussionsReplies: 2Last Post: 1st Mar 2010, 15:06 -
Jpeg compression taking much time
By mourya in forum ProgrammingReplies: 0Last Post: 18th Jan 2009, 16:47 -
DVD -> AVI -- reversing time compression (pref. wth VirtualDub)
By Calidore in forum Newbie / General discussionsReplies: 0Last Post: 20th Oct 2008, 14:22
