I have VHS wrestling videos which were converted to DVDs. I then demuxed the DVDs into MPEG 2 files (some of which are 704 x 480). I use this AviSynth script:
The "CPU=6" deblocks it so there is no pixilation whatsoever anymore and it also does pretty good noise reduction where it removes the background flicker and other noise. However it does blur the picture slightly. If I add the following script to the above script then it gives a perfect picture completely removing all forms of noise, it gives better black levels and it doesn't blur the picture:Code:Mpeg2Source("I:\New\1 = Test files\clip 704.d2v", CPU=6) AddBorders(8, 0, 8, 0)
McTemporalDenoise(settings="medium", interlaced=true)
However McTemporalDenoise takes over 20 hours with a 1 hour 15 minute file. Is there any script which will perform the same function as the above McTemporalDenoise script which takes 3 hours or less?
Closed Thread
I have VHS wrestling videos which were converted to DVDs. I then demuxed the DVDs into MPEG 2 files.
Could someone please suggest a script that will fix the colours along with hue, saturation, brightness, and contrast and anything else like that and good white and black levels. Some files have dull colours, others are fine. I need a script which I can use on any of my videos which will normalize the colours so they look normal on all my videos. If the colours are already fine in some of the videos then the script should have no effect. Would the following script do that?: ColorYUV(autogain=true)
What exactly is luma and chroma by the way?
The script must take 3 hours or less with a 1 hour 15 minute file.
The picture in some of my videos moves up and down every several seconds. Is there any way to fix that with a script? If so, could you please advise the best script to use.
The script must take 3 hours or less with a 1 hour 15 minute file.Last edited by VideoFanatic; 29th Sep 2011 at 23:06.
I saw the power of AviSynth videos such as this: http://vimeo.com/11133342. It looks like the video was unblurred so it looks like a DVD. Are there any filters that can do that (or get as close to DVD quality as possible) with VHS videos which were converted to DVD?
I would be working with an MPEG 2 file that I demuxed from the DVD.
I already use this script which deblocks and removes the noise but it doesn't increase the picture quality.
I know there are scripts that sharpen the picture but I don't know which to use and what script I should use.Code:Mpeg2Source("I:\New\1 = Test files\clip 704.d2v", CPU=6)
I have merged all your avisynth restoration questions. Keep them in one thread.
Okey. Use ONE THREAD for all your avisynth restoration. Continue in https://forum.videohelp.com/threads/339201-VHS-to-DVD-Restoration-Best-AviSynth-scripts...53#post2108553
How to increase the bitrate of a video by avisynth ?
By avengerevenge in forum EditingReplies: 31Last Post: 11th May 2013, 00:13 -
Should i use and avisynth script for Dv ?
By smartel in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2012, 08:29 -
If VHS was wider, would quality increase?
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2010, 05:25 -
use AviSynth script to add graphic idx/sub subs in DVD Flick?
By MilesAhead in forum SubtitleReplies: 7Last Post: 17th Dec 2009, 12:24 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00
