Hi, I have a strange problem that has recently started occurring with AVCHD disks I'm creating - playback on my Sony Blu Ray player is extremely choppy, yet the m2ts files on the disk and on the hard drive of the PC that was used to create the files, and burn the disks, play faultlessly on that PC.
Meanwhile, disks that I previously created using the same set-up still play fine on the Blu Ray player. I can also burn disks from the editing utility that came with my camcorder - Sony 'PMB' - that play correctly on the Blu Ray player (though I guess there is no reauthoring going on in that case).
Frame rate is 29.970, if that means anything, and the resolution is 1920X1080 - although the problem also occurred at a lower resolution. I'm using Cyberlink PowerDirector 8 to create the problem files.
Does anyone know what could be going on?
http://www.kiva.org/about -
What brand and type of discs are you using? I specifically want to know about the problem discs. Also, what speed do you burn at?
Would files created with incorrect encodes play correctly on the PC?
The disk files are produced using AVCHD export settings from PowerDirector 8. For burning, I used UDF2.5, and have tried various burn speeds, 3X, 6X, and 8X. I've tried a couple of burning programs, and even transferred the disk files to another computer and burned them to disk there. All disks exhibited the same problem in the Blu Ray player.
It's all so goddam weird. -
Not sure what type of disks I'm using - I believe they're Sony, but I can't check right now. However, I've been using the same disks from the same pack for a while, and previously burned disks are still playing in the Blu Ray player fine. As I was saying above, I've tried a number of burn speed settings.
In a nutshell - yes. You could indeed successfully play files on a PC that your player will vomit on.
Lower speed burning is ALWAYS better for this kind of issue, so if you do any more tests stick to 4x or lower. The problem could be bad media. Sony discs are a crapshoot with some coming from the best manufacturers and some coming from the worst. I've not heard of them mixing discs from different manufacturers in the same container, but I guess I wouldn't rule it out offhand either. The problem could be that your player is having problems. Or it could be that your burner has issues but since you tried burns on another PC, that's unlikely.
If you want to spend more money and rule out bad media, go online (sorry but going to physical stores won't help you here as all they sell are crap discs) to http://www.supermediastore.com or http://www.rima.com and buy some Verbatim DataLifePlus DVDs or anything by Taiyo Yuden. Burn at 4x or lower and see what happens. -
Most players won't play AVCHD camcorder format but will play an AVCHD disc format. I don't think Cyber producer v8 knows the difference. Current version is 11.
Try free multiAVCHD as alternate.
http://multiavchd.deanbg.com/tutorial.php
What model Sony BD player? They seem to vary on format support.Last edited by edDV; 1st Oct 2011 at 00:44.
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 19:25 -
NS-WBRDVD Blu-Ray player AVCHD issue
By Nexgen76 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 9th Jan 2012, 22:15 -
Choppy/jerky AVCHD/mts playback on my computer
By rlubocki in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 25th Dec 2009, 14:14 -
Choppy playback of HDTV to AVCHD
By Dr_Layne in forum Authoring (Blu-ray)Replies: 12Last Post: 18th Jul 2009, 10:17 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15
