I have a question about transferring a MAcrovisioned VHS tape to DVD. Can I rip it as is (a grey screen is the result) onto a DVD, THEN run THAT DVD through DVD Decrypter (or DVD Shrink, or DVD HD FabDeCrypter, or VobBlanker), or is there no picture at all on the burned DVD? The post on here that suggested that was not clear about that. If I can do that, will the then NEW rip have the unscrambled picture on it? Thanks!
"Ripping" means decrypting and copying a commercially produced DVD to your hard drive with all copy protection removed. Transferring a commercial VHS tape to DVD is not the same thing as ripping.
You can't use software to remove Macrovision from a VHS tape after capturing it with a DVD recorder. You can only use ripping software to remove Macrovision from a commercially produced DVD. As you suspected, there is no picture on the recorded DVD if Macrovision greyed out the video. You have to use hardware to remove Macrovision from VHS tapes while recording in order to transfer protected VHS tapes to DVD using a DVD recorder. -
Note if you only want to remove VHS MV no need to spend big bucks on a DVD type filter, cheap VHS filters are <$30 on the internet. That or if you have a old Beta recorder I've had luck installing them in-line(video in, video out) to remove CP.
Posts moved to its own thread.
What editing software to use after transferring VHS to DVD?
By garyg45 in forum Newbie / General discussionsReplies: 8Last Post: 3rd Mar 2012, 11:20 -
Question: Long horizontal scratches on VHS tape
By bisonrav in forum RestorationReplies: 12Last Post: 6th Mar 2010, 08:09 -
8 hours of MiniDV tape to DVD. Least painful method of transferring?
By Simmster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Nov 2009, 05:30 -
Transferring VHS to DVD
By Scotty427 in forum RestorationReplies: 50Last Post: 16th Aug 2008, 01:52 -
Question about capturing VHS tape to .avi file
By rfdillon in forum Capturing and VCRReplies: 6Last Post: 27th Jul 2008, 01:44
