I'm trying to convert an mp4 file to Blue Ray but Ripbot keeps squarshing it to 2.40 AR instead of keeping the 2.76 AR. I tried to set the size,1280 x 464 manually but then it tells me it's not standard frame size. Is there a workaround for this?
That doesn't work. When you select HDReady 1280x720 it also selects a 2.40 AR by default. I'm trying to preserve the 2.76 AR.
You can manually edit the script to achieve the resolution you desire then modify the border settings accordingly.
Last resort would be to select custom under the re-size field set the width at 1280 and height at your desired resolution. Then manually edit the avisynth script to add black borders to the top and bottom of the video.Murphy's law taught me everything I know. -
Thanks for the reply. I converted it with BDtoACHD after converting it to mkv format. That preserved the correct AR.
Aspect Ratio Help
By darkdream787 in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2011, 02:53 -
Correct Cropping/Aspect Ratio with Ripbot vs Handbrake
By Tony Jenkins in forum Blu-ray RippingReplies: 16Last Post: 20th Jun 2011, 16:47 -
wrong aspect ratio using ripbot
By magmo in forum Video ConversionReplies: 2Last Post: 12th Mar 2009, 08:15 -
Ripbot - FFDSHOW settings aspect problem
By Melmac77 in forum DVD RippingReplies: 0Last Post: 23rd Dec 2008, 01:53 -
Aspect ratio
By Digiface in forum Software PlayingReplies: 2Last Post: 24th Aug 2007, 12:35
