First time doing it
Wondering if there was a faster way to encode using TMPGEnc ???????????
it takes me like 6 hrs for half a mov !!!
any info would help
THANKS
GABE !!!!
Results 1 to 11 of 11
you know its enough when someone helps ! i guess theres only a few people left in this world that actually belive in say yea it takes that long or no try this thats all werelooking for !! ok i dont know alot about this at all just trying to learn
First of all how fast is you CPU? The simple answer would be to get a faster CPU, cause 6 hours seems alot for an hour's worth of video. Are you encoding in Mpeg1 or Mpeg 2? Mpeg2 takes longer to encode. Are you using any of the built-in filters, cause these will also increase the encoding time. Lastly if you really want faster encoding you might want try a different program (ie CCE SP ) but I'd stick with TMPGEnc,you can't beat the price.
hey thanks alot man !! yea ill check mpeg 1-2 !!! and thanks for the reply ! well i have an amd 700 mhz 256 megs ram and 20 gig hd i dont think thats 2 slow !! but maybe
MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 48000Hz 192kbps -
tmpeg takes me 8-10 hours to do a 2 hour movie into mpeg2 .. and i have a dual amd 1G ... cce takes 4 ( 2 single vbr passes ) .... but for the price .. tmpeg is worth it ... just hit start .. go to sleep ( or work ) ... hope it's done when you wake up ( or get home ).
The Fastest way I know of is to use LSX. LOL
I use both Tmpeg and LSX they both have advantages and disadvantages. Like every thing there is no One perfect program.
cool thanks !! i was wondering where and how much the program cce is ?? and whats the full name ????/
CCE = Cinema Craft Encoder
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Hey Corliss,
I have a Duron 900mhz cpu and I've been getting the same conversion times. Just bought an Athlon 1800xp cpu. That alone should cut my conversions times in half from what I'm hearing from everyone else.
I just ordered a magicjack and was wondering if anyone else used one
By johns0 in forum Off topicReplies: 9Last Post: 4th Oct 2010, 02:46 -
Was wondering if such a thing exists....WAN (Wireless USB connector)
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 3rd Oct 2010, 04:53 -
i have this mp4 and i was just wondering....
By tryvora in forum Video ConversionReplies: 2Last Post: 30th Jan 2009, 23:04 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 23:21 -
VRO to MP4 - please suggest a faster converter than TMPGEnc Xpress 4.0
By mbextreme in forum Video ConversionReplies: 2Last Post: 26th Aug 2008, 18:24
