Results 1 to 11 of 11
    Sep 2011
    The Netherlands
    Hello.
    I am trying to embed the code for a .flv video on my website http://www.mirtos-reizen.nl/wegennet.html.
    It works fine under Internet Explorer, but does not start under Firefox, what am I doing wrong?:
    <!-- MC Media Player -->
    <script type="text/javascript">
    playerFile = "http://www.mcmediaplayer.com/public/mcmp_0.8.swf";
    fpFileURL = "http://www.mirtos-reizen.nl/wegennet/100_4017.flv";
    playerSize = "500x375";
    fpAction = "play";
    defaultEndAction = "stop,fpButton=off";
    cpSize = "960x24";
    cpHidePanel = "mouseout";
    </script>
    <script type="text/javascript" src="http://www.mcmediaplayer.com/public/mcmp_0.8.js"></script>
    Something is wrong with the js file, http://www.mcmediaplayer.com/public/mcmp_0.8.js .
    I receive a javascript error
    [13:05:43.541] illegal character @ http://www.mcmediaplayer.com/public/mcmp_0.8.js:1
    Did you upload it as a text/ascii if you are using a ftp?
    Sep 2011
    The Netherlands
    I uploaded it as a .html file.
    It should work then. Strange. Try upload again.
    Sep 2011
    The Netherlands
    It doesn't work yet, I use the same code as http://www.videoholland.tv/agios_ned.html f.i., perhaps you could look at the source, maybe I am forgetting something...
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    No. I can't see any difference. But redownload mcmp_0.8.js from http://www.mcmediaplayer.com/about/history/altair/0.8.html and upload.
    Oct 2010
    England
    Might be a long shot, but it looks like the syntax isn't right here. Maybe this instead:
    defaultEndAction = "stop";
    fpButton = "off";
    which more closely matches the other parameters.
    I wouldn't have thought this would stop the player loading though...
    Excuse me asking the obvious, but has Firefox got a recent version of Adobe Flash installed and javascript enabled? What version of FF are you using?
    Sep 2011
    The Netherlands
    Doesn't work either intracube, I never use Firefox normally, just for this purpose I just downloaded it, version 7.0.
    I have not installed anything as on www.videohollang.tv I can watch all the movies with the Firefox I use and not the movies om my website, very very strange...
    Oct 2010
    England
    I took a copy of your webpage and associated files. All I saw when trying to view it on my computer was the raw html with additional non ASCII characters.
    The actual webpage is UTF-16le encoded, but charset="UTF-16" is specified within the webpage. I converted the page to UTF-8 and modified the charset to read charset="UTF-8" and Firefox then loaded the page.
    Here's some more info on the character encoding issue:
    http://superuser.com/questions/23777/firefox-displays-garbage-characters-in-lieu-of-web-page
    I don't know the easiest way to change the file encoding with Windows (I use Linux). Hopefully someone can give you a suggestion.
  10. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    With UTF-8 and roughly cleaned up code (tag nesting errors), the page loads fine, including the video, in all the browsers I have installed here (Safari, Firefox, iCab).
    The swf, js and flv file are okay. It is the html file that needed fixing.
    (You could make better use of CSS, to avoid the <font> and <center> tags, but that is for a next clean-up... )
    (Attached file is RAR'ed so the board will allow the upload of an .html file. Unrar with your fav decompression utility.)
    Sep 2011
    The Netherlands
    Intracube and Case
    I can't thank you both enough !!!!
    Saving the file as UTF-8 was the solution... How stupid of me not to see that.. thans, thanks, thanks, what a great forum with great users this is!.
    Next I will take an aspirin against the headache and wish you all a very nice day.
    Best regards
    Ron Vos
