  1. Hello.
    I have DVD which resolution is 720x480 4:3
    I want to rip it but AutoGK upscales resolution to 720:544, why ?
    I ripped a lot of DVDs and agk always lowered height of movie (of course keeping AR), so I found this strange.
    Here is the log:
    [2011-09-26 18:31:24] AutoGK 2.55
    [2011-09-26 18:31:24] OS: WinXP (5.1.2600).2
    [2011-09-26 18:31:24] Job started.
    [2011-09-26 18:31:24] Input file: M:\Grande illusion, La\VTS_02_0.IFO
    [2011-09-26 18:31:24] Output file: M:\Grande illusion, La.avi
    [2011-09-26 18:31:24] Output codec: XviD
    [2011-09-26 18:31:24] Audio 1: Francais AC3 1ch
    [2011-09-26 18:31:24] Subtitles: none
    [2011-09-26 18:31:24] Format: AVI
    [2011-09-26 18:31:24] Target size: 1493Mb
    [2011-09-26 18:31:24] Custom resolution settings: fixed width of 720 pixels
    [2011-09-26 18:31:24] Audio 1 settings: Original
    [2011-09-26 18:31:24] Started encoding.
    [2011-09-26 18:31:24] Demuxing and indexing.
    [2011-09-26 18:38:20] Processing file: M:\Grande illusion, La\VTS_02_1.VOB
    [2011-09-26 18:38:20] Processing file: M:\Grande illusion, La\VTS_02_2.VOB
    [2011-09-26 18:38:20] Processing file: M:\Grande illusion, La\VTS_02_3.VOB
    [2011-09-26 18:38:20] Processing file: M:\Grande illusion, La\VTS_02_4.VOB
    [2011-09-26 18:38:20] Processing file: M:\Grande illusion, La\VTS_02_5.VOB
    [2011-09-26 18:38:20] Processing file: M:\Grande illusion, La\VTS_02_6.VOB
    [2011-09-26 18:38:20] Processing file: M:\Grande illusion, La\VTS_02_7.VOB
    [2011-09-26 18:38:20] Processing file: M:\Grande illusion, La\VTS_02_8.VOB
    [2011-09-26 18:38:20] Source resolution: 720x480
    [2011-09-26 18:38:20] Found NTSC source.
    [2011-09-26 18:38:20] Source aspect ratio: 4:3
    [2011-09-26 18:38:20] Analyzing source.
    [2011-09-26 18:47:49] Source has percentage of interlacing in motion areas: 37,24
    [2011-09-26 18:47:49] Source has percentage of telecined patterns: 97,27
    [2011-09-26 18:47:49] Source has percentage of progressive patterns: 2,31
    [2011-09-26 18:47:49] Source has percentage of interlaced patterns: 0,42
    [2011-09-26 18:47:49] Source is considered to be FILM.
    [2011-09-26 18:47:49] Output will contain 182855 frames
    [2011-09-26 18:47:49] Using VAQ in XviD
    [2011-09-26 18:47:49] Audio1 size: 183,036,672 bytes (174.56 Mb)
    [2011-09-26 18:47:49] Overhead: 1,271,040 bytes (1.21 Mb)
    [2011-09-26 18:47:49] Video size: 1,381,216,256 bytes (1317.23 Mb)
    [2011-09-26 18:47:49] Running compressibility test.
    [2011-09-26 18:47:49] Writing the following script to M:\agk_tmp\Grande illusion, La_comptest.avs
    [2011-09-26 19:12:11] Duration was: 24 minutes 21 seconds
    [2011-09-26 19:12:11] Speed was: 6,26 fps.
    [2011-09-26 19:12:12] Compressibility percentage is: 37,38
    [2011-09-26 19:12:12] Using softer resizer.
    [2011-09-26 19:12:12] Chosen resolution is: 720x544 ( AR: 1,32 )
    [2011-09-26 19:12:12] Predicted comptest value is: 38,77%
    [2011-09-26 19:12:12] Running first pass.
    It resizes all video to 4:3 resolution (or 16:9). If you want to keep it in 720x480 you have to use something else.
  3. Originally Posted by ralf07 View Post
    Because you chose a fixed width of 720. Look at what you have in the Advanced Settings:
    If you don't want a width of 720 (and for this project you don't because the resulting quality, in spite of AutoGK's best efforts, is lousy), either choose a lower width (one such as 640) or (better) set it to AutoWidth and let AutoGK choose the best width that'll give you good quality for the size you want.
