My battery is not working suddenly.On the little icon where it's supposed to show the battery charging written "Plugged in but not charging.".I left my laptop for about 2 months because I was away then I got back home and this happen.Can someone help me solve this problem?
I can't live without my computer.
My wife's laptop battery completely died (stopped charging) after only a few years.
Replace the battery(if it's out of warranty) or contact the company to get warranty work done on the laptop. -
May be corrosion on the contacts. (Especially in the tropics as we are.)
Take the battery out and carefully scrape the contacts on it and in the compartment in the laptop.
E.g., use a small screwdriver.
Wipe clean (I use a cotton bud with a drop of WD40).
Wipe dry again and see if it works. -
If the charging circuit inside the battery detects a fault condition (such as a dead battery) then it won't do anything. If this is the case, then your battery is a brick and needs to be replaced.
How old is your battery? Over 2+ years and the life expectancy has been exceeded anyway.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Make and model of laptop ... some issues are common and easy to determine but we will never know what without this information.
Some sony and hp units need the following done to fix common battery issues.
Take the battery out, remove power and hold down power button for 30 seconds ... then plug in mains power followed by battery and fire it up again.
Laptop battery sources
By ranchhand in forum ComputerReplies: 3Last Post: 4th Jan 2012, 07:56 -
laptop battery question
By bballnut in forum ComputerReplies: 7Last Post: 30th Apr 2011, 13:07 -
Laptop replacement battery ?
By Noahtuck in forum ComputerReplies: 8Last Post: 10th Jan 2010, 13:54 -
laptop battery
By romanstopme in forum ComputerReplies: 7Last Post: 23rd Feb 2009, 04:03 -
laptop battery replacement
By gooberguy in forum ComputerReplies: 9Last Post: 15th Jul 2007, 05:25
