Hi,
in following these steps:
http://www.vcdhelp.com/divxcap.htm
I ran into a problem at the very end.
Select under Audio->Compression and select DivX or MPEG3 128kbits 44100hz
I can't find Mpeg3 at that bit rate. The max is like 56. I just caputerd from VCR following those steps.
I could've sworn that in the past I used to have that bit rate.
Also when I choose Divx audio compression, it seems to take forever when I save the file. Is that normal?
Best Regards
Are you sure you have it installed, it is the Radium codec you can go to google and do a search for it, i dont remember the website. sorry, hope this helps.
Thanks jen_jen, That worked.
It's funny because in VirtualDub, I already had an MPEG-Layer 3, the one that was limited to 56. Now I have 2 entries, the new one has all the bit rates!
It seems to be working, I'll leave it alone
Cheers
pctv TVCenter versions & multiple installs
By Davalan in forum DVB / IPTVReplies: 0Last Post: 15th Apr 2011, 05:35 -
transfer programs across xp installs (on 2 different hard drives)
By greymalkin in forum ComputerReplies: 2Last Post: 17th Nov 2009, 06:11 -
MP3 codec for AviSource?
By AlanHK in forum Software PlayingReplies: 5Last Post: 29th Sep 2009, 23:53 -
Did I install the wrong mp3 codec?
By Havoc X in forum Software PlayingReplies: 3Last Post: 2nd Jun 2008, 22:22 -
MP3 Codec for Nero Vision
By danielivo in forum AudioReplies: 6Last Post: 29th Mar 2008, 08:02
