Hello all- I'm using Edius to create AVI files. These are AVIs with uncompressed YUY2 video. The audio is 48kHz/24bit, but I can't figure out what codec is being used for it. I'm attaching an export from MediaInfo which tried to identify the codec. Also, when I play the file in VLC the video works fine, but I get a message that the audio format is undf.
What would cause this and how do I fix it? Thanks in advance!
did you try reading the manual? or watching any of the tutorials? pcm is a wav file but that's not a normal template. 8ch, 24bit.
The manual just tells me it's PCM. There's no way to capture other than creating a file with 8 audio channels.
what type of video are you capturing? what hardware? have you tried something else to capture with?
According to what that MediaInfo says, it's LPCM, 8ch, 24bit, 48kHz. That's UNCOMPRESSED, like WAV. It's just uncommon, because of the high bitdepth and multichannels.
Are you trying to open them in Edius? or Output them?
It's been a while since I dealt with this kind of audio, but I could look and find out which Audio apps support it...
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 20:20 -
no audio during convertion of avi files
By blossom_suki in forum Video ConversionReplies: 7Last Post: 12th Apr 2010, 12:15 -
help w 'unknown' avi file
By rotuts in forum MacReplies: 7Last Post: 28th Feb 2008, 10:16 -
2 audio AVI files
By warlock110 in forum Video ConversionReplies: 3Last Post: 7th Jul 2007, 21:18 -
AVI files with 2 audio channels
By danjull in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 05:57
