I'm using MultiAVCHD to create a BD-R disc with a bunch of separate M2TS files. This works perfectly, however, I'm not able to skip between titles with the remote. Is there a setting or a possibility that I'm not seeing, that will allow the player to skip between titles? I can choose title in the menu that MultiAVCHD creates, but for the use I have for this specific purpose, it would be really useful to be able to just skip, like you do with chapters. Any ideas?
you have a couple options:
1. using the pop-up menu (make sure it's selected in the "author" tab under the heading "menu style and options"), you can advance to the next title (and backwards), or go to the title menu, etc.
2. under the "author" tab. look under the "video & chapters" heading and make sure "add chapter at ttile end" is selected. then you can advance to the next title by advancing through the chapters.
i hope that helps.
MultiAVCHD problems; chapter selection crashes program; changing title
By Yanta in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2011, 16:48 -
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 19:49 -
Toshiba DVR620KU Makes title named Blank Title, when I finalize a disc.
By Dim29 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 20:18 -
Can title menu have active multiple thumbnails using CXtoD (using 1 title)?
By bobbyg in forum Authoring (DVD)Replies: 1Last Post: 26th May 2010, 09:32 -
Sony DVD-Architect: Title advance (skip) in playlist faulty?
By mltwitz in forum Authoring (DVD)Replies: 1Last Post: 28th May 2007, 13:07
