Hello friends
I have compiled a Slide Show DVD which has 6 VTS. I used Slideshow Author GUI to create the DVD. Each VTS contains only one PGC. Once the PGC of a particular VTS is finished, the DVD jumps back to the main menu which is nthing but a page with links to the different parts of the slide show. Is it possible to make the DVD play continuously to the last VTS unless the Menu" button if the remote is pressed. I tried to change the command structure of the last cell of a PGC in a particular VTS under "Cell Commands" in DRMP, but could not achieve the desired result.
Is it possible to make the change at all? If yes, please tell me how.
Thank you
আমি বাংলায় গান গাই
You can not jump into a video title set (VTS) from another. You must go thru the video title set menu (VTSM) to do this. Just put a end action to jump to a menu item and set that menu item to auto jump to the VTS that you want next.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
আমি বাংলায় গান গাই
This one: https://www.videohelp.com/tools/DVD-slideshow-GUI ?Slideshow Author GUI...
Is not creating the DVD itself. It uses other programs (like GFD) to actually 'create' the DVD. Which one have you used? If it was GFD, what was the setting of the authoring engine, dvdauthor or muxman?GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
It's in the post-command list of the VTS title's PGC. In the end of a PGC's playback the commands from that list are performed. Currently it's a command leading to some VTS menu. Instead of that command you want to have the one sending playback to a new empty PGC with its new number, created in VMG (a command like 'Jump VMG PGC#'). That empty PGC must have a pre-command for starting next VMG title (Jump VMG Title #), etc. In this way you can edit your DVD with PGCEdit or DVDRemake.
How to Be Sure It Will Be Possible to Revert to Previous OS Boot?
By jeanpave in forum ComputerReplies: 4Last Post: 1st Nov 2011, 19:41 -
VLC: opening at previous size?
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2011, 02:45 -
Previous Versions of tsMuxeR
By DirectorSG in forum MacReplies: 2Last Post: 18th Sep 2010, 06:44 -
New PC encodes significantly slower than previous PC
By Smells_Like_Feet in forum ComputerReplies: 16Last Post: 26th May 2009, 15:08 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 12:28
