I have a device(DVB) that records their videos(and can play) with this application(BlazeDTV 6.0).
But I can't play these files out of application.I install latest version of K-Lite(7.7-Full)But not work.I get this properties from Media Player Classic:
General
Complete name : H:\2011-9-19-20-41-51.mpg
Format : MPEG-PS
File size : 45.5 MiB
Duration : 2mn 31s
Overall bit rate : 2 523 Kbps
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=4, N=25
Duration : 2mn 30s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Color primaries : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM
Transfer characteristics : BT.470-6 System B, BT.470-6 System G
Matrix coefficients : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM, IEC 61966-2-4 601
Audio
Format : MPEG Audio
Duration : 2mn 31s
Compression mode : Lossy
Delay relative to video : -860ms
Is there any idea?
Results 1 to 16 of 16
Aye. That video seems to be screwed up. AVC in an mpeg ?
May also be worth trying (nothing to lose) just renaming it to .mp4 -
I'm pretty sure you can have avc video in a mpg/mpeg-ps container. But I guess many players doesn't like it.
I rename extension of file from mpg to mp4 then Media Player can open file but play that with noise and problems.
I upload a small zipped clip(4second) for investigation.
Thanks. -
My guess is that BlazeDTV prog is creating a proprietory file - AVC + mp3 in a mpeg container is somewhat unusal to say the least. The proprietory nature means that only their player + their codecs can play the darn thing properly - I could also, like the others, see the video but not hear the sound.
But I notice from their website that the pro version of their player claims to convert these files in to standard playable formats avi etc. That may well be your only option. -
WTFID : 192 (0xC0)
Format : MPEG Audio
MPEG-Audio "2CC" = 50 (MP1/MP2) or 55 (MP3)
To make things worse:
=>ffmpeg -i 38.mpg
ffmpeg version N-32071-g276f43b, BLAH-BLAH-BLAH
[mp2 @ 01FD1AA0] Header missing
Last message repeated 5 times
[mpeg @ 01EDB000] Could not find codec parameters (Audio: mp1, 0 channels, s16)
Seems stream 1 codec frame rate differs from container frame rate: 50.00 (50/1) -> 50.00 (50/1)
Input #0, mpeg, from '38.mpg':
Duration: 00:00:02.86, start: 0.000000, bitrate: 2784 kb/s
Stream #0.0[0x1c0]: Audio: mp1, 0 channels, s16
Stream #0.1[0x1e0]: Video: h264 (Main), yuvj420p, 720x576 [SAR 12:11 DAR 15:11], 50 fps, 50
tbr, 90k tbn, 50 tbc
At least one output file must be specified -
The audio is actually misidentified; it's LATM HE-AAC V2
Not very many programs have support for LATM AAC audio , winamp can convert it.
If you have LAV splitter and audio decoder installed and configured it should be able to play (but I couldn't get it to play for some reason, even though it detected audio - audio was blank)
This is what I did
1) tsremux to re-wrap into .m2ts
2) eac3to to demux audio & video
e.g.
eac3to input.m2ts -demux
3) winamp to convert the aac audio to wav (or something else like AC3, but I left it uncompressed for this test)
4) re-wrap original demuxed video along with converted audio with tsmuxer into .m2ts transport stream
I had to enter audio delay of -720ms, but your sample was too short to know if it was ok
mediainfo stated -360ms delay on original video, but it was too short when I tested it
Delay relative to video : -360ms -
That's a lot of work just to get the darn thing to play.
Noticed that the converted file appears shorter in running time to the original so I do wonder if that also had some influence in the failure to render any audio.
BlazeDTV still appear to call these mpegs 'mpeg[video]+mp3[audio]' and one would think they know what they are talking about. But apparently not.
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
how to split mkv file and subtitle file to play on blu ray via hdd usb
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:28 -
burning mkv file and separate srt file to play on dual layer disc
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:26 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36
