i need to join two equal length videos so they overlap each other. for example im filming one room and there is one chair for 2 30 second clips. i put an object on the left side of the chair and in the other video i put it on the right, i want the final video to show that two people put two objects on that chair in the at the same time for the same 30 seconds. please this is very important i need this answered asap. i have adobe premiere/ after affects 5 encase that helps.
	Read up on compositing. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
  Screen Captured vidoes always lag when played back.By techspark in forum Capturing and VCRReplies: 2Last Post: 27th Apr 2012, 19:50
  Fix overlap of opaque boxes with VobSub (semi-transparent)By Pie in forum SubtitleReplies: 1Last Post: 22nd Apr 2012, 10:32
  Symptom of picture overlap in motion.By wisitch in forum Video ConversionReplies: 6Last Post: 8th May 2010, 21:06
  joining two avi parts that overlap?By nok32 in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2008, 04:40
  What software would you use to overlap video?By D.A.R.J.R. in forum EditingReplies: 2Last Post: 18th Apr 2008, 01:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
