Hi all!
I'm trying to convert AVI to MP4
All my 40min AVI videos are about 350mb
but my 40min MP4 videos are about 100mb, with the information below
Video Info: H264, 640x432, 23.98 Hz
Audio Info: AAC, 2Ch/48.0KHz/32bits
Audio/Total: 01/01
The MP4 videos I have, have very similar quality to the AVI videos, the main difference is the size.
I want to convert my AVI to MP4 to save disk space, if possible.
If anyone can help me with this it would be very much appreciated since I'm a total n00b! =D
Use handbrake, open avi, choose container: mp4, under the video tab set the target size to around 100 mb, convert. Done.
You can also use the very simple Freemake Video Converter or more advanced tools like Avidemux, Xmedia Recode, Ripbot264. But you might havet to calculate the bitrate manually(with a bitrate calculator) to get size you want. -
Try Drag Drop Convert GUI v 1.0.0.1
1. "Encode option" checking "Encode Video and Audio"
2. Select quality, if you want to play it on another device then "Baseline" for save but if you play it on PC only then "High10" for smaller size.
3. Change speed to nearly compress (1 tick before end)
And then Drag and drop all file you want to convert to drop zone.
After all file encode then move them to new folder, change tab to "Content" tab, select all .h264 file and drop them into "content to" zone.
I use this program covert all video in my HDD for sake of my disk space too.
But beware filename, it can cause a problem(space and non-english char).
If you have a problem with filename, try to change it to some simple name before encode like Song.Avi
loop mp4 or avi locally so will play on mp4 player - ?
By marinebc11 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 21:24 -
avidemux newbie: mp4 in; avi out has no video; mp4 out has washed out video
By nonexistent_entity in forum Video ConversionReplies: 1Last Post: 22nd May 2010, 15:46 -
Best software to convert VOB to mp4 or AVI, or AVI to MP4?
By 80zforever in forum DVD RippingReplies: 7Last Post: 18th May 2010, 13:32 -
Converted avi files darker than originals (avi to mp4)
By Hal05154 in forum Newbie / General discussionsReplies: 3Last Post: 5th Mar 2009, 20:06 -
AVI to mp4 Freeware and VOB to mp4 Freeware
By saucedmike in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 02:44
