    Feb 2009
    I have been trying to back up some of my Blu-Ray DVD's in Toast 11 and have some issues. I have been ripping the BR discs using MakeMKV software and then using ps3muxer i convert the .mkv file to a .m2ts file for importing into Toast 11 (MAC).
    The problem I am having in Toast is the origional .m2ts file (13.95GB) that I import into Toast converts to a (461.2 MB) file in toast.
    In Toast "Video" the following options are available; DVD-Video, High Definition DVD-Video, Blu-ray Video, BDMV Folder, and AVCHD Archive. I assume that either Blu-ray video or High Definition DVD-Video would be the one to use. Blu-Ray video being the one I would think you'd use.
    But everytime I import the 13.95GB file it shows it converted to 461.2MB. How can I get the entire 13.95GB high-res file to burn for viewing on my "home Blu-Ray DVD player"? ***Note: 2 screen shots have been attatched for clearity. Any help would be appreciated! Thank you!
Name:	Toast M2ts?.jpg
Name:	Toast Options.jpg
    Have you just tried one mkv or does this happen with all?
    Or maybe try find a blu-ray ripper that doesn't make a mkv so you can just rip and burn the bdmv folder directly. I have not seen any free blu-ray ripper for mac though.
    And moving you to our mac section.
  3. Member terryj's Avatar
    N35°25.24068, W097°34.204
    I'm with Baldrick on this one.
    I believe the problem is too much transcoding: from Blu-Ray to MKV to MTS again.
    IF you can rip the Blu-Ray to the HD ( I dunno, maybe using MacTheRipper 4.1.5.2 ?)
    then you should be able to use that output and just drag drop it into Toast
    and burn another copy under the Data tab?
    Sorry, I don't do Blu-Ray or use Toast 11...
    I'm still sticking with SD content and Toast 10 for now...
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  4. Just a heads up, and I apologize if you already checked this, but I had a similar screwy problem with compilation DVD's I was creating in Toast...
    In your screen shot #1, you have the "Media" tab highlighted. Check the "Options" tab, and notice if the choice: "Use Fit-to-DVD video compression" is unchecked.
    If this is checked, it ignores some of your other logical encoding/burning choices, and spends extra energy re-compressing everything...
