Hello. I have used powerdvd 11 to play a BDMV folder, it plays some folders, and other it wont play so its not a stable solution for me.
Therefor i have downloaded MPC HC cause it plays everything. I just got one very weird problem, the quality in mpc isnt as great as in PDVD. In PDVD i get that great bluray feel, not the artificial look that is caused by some tv settings, just a great bluray feel. I cant get that in mpc. All settings are completely the same (tv, catalyst control center) the only thing i have changed is im using MPC.
Results 1 to 10 of 10
Tried, didnt notice anything big. There might be alittle difference between some of them but the image isnt crystal clear. Its a full bluray disc thats beeing played just in case
Thx for helping -
Thanks. Gonna give it a try. I just dont have good know how in those areas.
Last edited by El Heggunte; 26th Sep 2011 at 14:40. Reason: misunderstanding =^.^=
In my opinion players like PowerDVD corrupt the picture. Well produced material doesn't need to have the contrast stretched, the colors more saturated, the picture sharpened, or denoised. Get your system set up properly then watch the movies the way they were intended to be seen.
Changing VLC or MPC settings to maximize quality?
By awaisuk in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2011, 06:51 -
How to save Re:Quality guide for HTPC, how to configure MPC-HC, ffdshow, et
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2011, 08:09 -
Vid quality better in MPC (Windows), than MPlayer (Linux)...
By cwb in forum Software PlayingReplies: 3Last Post: 5th May 2010, 21:01 -
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 10:52 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 21:41
