Why when im burning a vcd and i put it in my APEX 1500 it goes out of sync. When its an mpeg file on my computer its fine and its in perfect sync. Audio and Video are together perfectly. After i burn it though and put it in my player the audio and video is off. Why does this happen? Is there any way to correct this problem. The program i use to burn the cds and make it a vcd is Nero.
The more important question is what do you use to multiplex with? By default I don't believe TMPgenc adds svcd scan offsets to its exported mpgs. If you use this to encode, or any other encoder for that matter, you will probably need to remultiplex your audio video streams to make them fully compliant. Try using bbmpeg to multiplex your streams, its much better than TMPGenc. I have an Apex AD600a and mpgs straight out of TMPGenc always play out of sync but if I use bbmpeg it fixes it every time.
Also you may want to use a better burning program than Nero. For vcds its fine but its not very good for svcds. I would use a program like vcdimager to author your svcd into a bin and cue and then burn that. There are free programs which can burn bin and cues if you don't feel like buying new burning software.
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
Apex DVD player AD-1100W - remotes compatibility
By Matthias in forum DVD & Blu-ray PlayersReplies: 5Last Post: 2nd Dec 2008, 13:16 -
How to capture Real Player movie from site to computer?
By Chana1 in forum Video Streaming DownloadingReplies: 17Last Post: 14th Apr 2008, 08:10 -
Subs sync ok on computer but off in player !
By dexterdoo in forum SubtitleReplies: 1Last Post: 15th Jan 2008, 14:05 -
taking audio from one movie to sync in a movie
By bigdaddykane in forum AudioReplies: 9Last Post: 28th Dec 2007, 13:40
