I'm a nebie to this so please excuse me if I've overlooked something basic. I can' t seem to get TMPGEnc to convert to widescreen with a widescreen film. It always "stretches" the aspect ratio to a full verticle image...Here's the part I don't get: I have tried EVERY input source setting from the "1:1VGA" right down to the bottom (4:3, 16:9 etc, etc.) with the exception of the PAL settings). None seem to make a difference. I am using smartripper and dvd2avi, both of which recognize the 16:9 format. I have also burned a few SVCD samples to see if it is widescreen on my home DVD/ TV setup, but the final product is always a stretched image...
Please help!
Results 1 to 10 of 10
first off....dvd2avi tells you the source aspect ratio to enter into tmpgenc..
widescreen movies can be either 4:3 525 line NTSC or 16:9 525 line NTSC....however, full screen movies have to be 4:3 525 line NTSC
also....do you get the scretched images on your computer also?
if it only occurs while you're watching on your standalone dvd player..it could be u need to change the settings on the dvd player....i think the defult is for 16:9 widescreen TVs...but most of us still have the 4:3 TVs -
Yes, thats the part that has me baffled. DVD2AVI says 16:9, so thats what I tried. I also tried every other setting! All resulted in the vertically streched image both on my computer (during the "preview" and also while using media player) and home DVD player.
I think I may be missing something simple, but I've played with almost every setting I can find to no avail. Very frustrating! -
simmons3d, how about the settings on your standalone dvd player?
there's usually a setting that u need to indicate what type of TV you have...either the standard 4:3 or widescreen 16:9 TVs -
First, do what "poopyhead" suggested and check your dvd player settings.
If that still does not work, make sure your TMPGenc settings are as such: 1:1 (VGA), Full Screen (keep aspect ratio) NOT Full Screen (keep aspect ratio 2). That should work. . I've used DVD2AVI and TMPGenc in tandem and have had no such problems. -
in the Advance tab:
Make sure the source aspect ratio is set to 16:9.
Make sure the Video arrange method is set to Full screen (keep aspect ratio)
Again, I strongly suggest you use DVD2SVCD to rip dvd`s to SVCD, especially if your a noob. Dont be intimidated by its numerous settings, it will be 95% set after you install it. Just make sure you set the encode tab to tell it where TMPGEnc is. -
Success!!! Thanks you guys... I thought I had tried that combo (16:9 and full screen keep aspect ratio), but I did it again and voila - its widescreen.
Thanks again! -
What problem did you find with "keep aspect ratio 2" ?Originally Posted by videoguy79
I'm using it and I don't find any difference with "keep aspect ratio".
Far as I know, there is non context help about it to explain the difference between the "keep" and the "keep 2".
Did you find some problems o information about it ?
Giuliano -
Giuliano, the difference is when playing in media player...i believe keep aspect ratio 2 will add black bars while you're playing it in mplayer...but 'm not sure...it could be the other way around
Sorry.. I've only testet it in the standalone player (philips 711)Originally Posted by poopyhead
Giuliano
Anamorphic widescreen with TMPGenc Author Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2010, 02:26 -
AVC conversion, Widescreen frame size, editing with Prem Pro CS3
By Soul_Survivor in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 08:44 -
Widescreen to fullscreen conversion
By F8L23 in forum Video ConversionReplies: 15Last Post: 13th Dec 2008, 12:38 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 02:40 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
