I have a video i took with my webcam. It has brief little pauses in it, because i had tooo many things going on the pc at the same time, and the programs were having a tug of war with the memory i have in it (1gb). It smooths out about a minute later, but at the beginning, it's struggling to keep a consistant flow. Is there any way to fix things? I will post a link to the video in a little while.
Thanks!
It's easy to cut out duplicate frames but there's no way to really recreate missing frames, especially if several in a row are missing. You can try using AviSynth and some motion interpolation software like MvToos in AviSynth. That works fairly well for simple motions, not so well for complex motions.
MPC-HC : audio does not pause when video pauses for H264 video
By kswartz in forum Newbie / General discussionsReplies: 3Last Post: 28th Jul 2011, 02:56 -
How to capture Streaming video and remove pauses
By bpatters69 in forum Video Streaming DownloadingReplies: 4Last Post: 23rd Feb 2011, 09:09 -
DVD video pauses every 30-35 seconds
By LoopyCoder in forum DVD RippingReplies: 0Last Post: 9th Apr 2008, 15:43 -
Overlaying/generating beeps & pauses during video
By jmelvin in forum EditingReplies: 5Last Post: 27th Feb 2008, 01:29 -
Video backups contain pauses
By dadbackup in forum DVD RippingReplies: 10Last Post: 15th May 2007, 16:13
