I recorded an .avi using huffyuv compression. The video will play fine on my computer. But I absolutely cannot get Vegas to open it at all, despite the fact that the proper codec is installed. It won't let me drag it over to add to the session, and if I simply double click on the file I get an error occured while opening a codec.
The codec works fine, but Vegas seems to be unable to perform the simple function of opening a file. What gives?
Windows has two built in video subsystems, DirectShow and VFW. Codecs for one don't work with the other. In addition, any program can use its own private internal codecs. If you are running 64 bit Windows there are both 32 bit and 64 bit versions of each of those video subsystems. 32 bit programs can't access 64 bit codecs, and vice versa. So just because you installed a codec doesn't mean that every program will have access to it.
That said, I know people are using HuffYUV with Vegas. So it's just a matter of getting the right version. If you're running a 64 bit version of Vegas make sure you have a 64 bit HuffYUV decoder.
Editing .264 video from mini-cam in Vegas: Vegas won't read video
By bigass in forum EditingReplies: 3Last Post: 27th Dec 2010, 11:35 -
Vegas : best codec for editing?
By grendizer in forum EditingReplies: 6Last Post: 18th Aug 2010, 06:20 -
Best AVCHD codec that will work with Vegas?
By The111 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Nov 2009, 21:54 -
Vegas 8.0 does not work
By romanstopme in forum ComputerReplies: 10Last Post: 24th Mar 2009, 22:48 -
m2t files won't work in Vegas Pro 8
By Patokid in forum Newbie / General discussionsReplies: 12Last Post: 21st Jan 2009, 14:47
