Any simple program to tell if a video file is using X264? I have a MP4 video that wont play on my xbox 360.... it see's the file and name and thats it's an MP4 but is not supported...
Results 1 to 17 of 17
OK.. showing my ignorance here...... after a little reading..... AVC is, can be x264? codec id = isom?? sound more like it?
Is it really an MP4 file? Anybody can rename a file with whatever extension they want. What did MediaInfo say about the container?
If it is MP4 it maybe encoded with settings the xbox 360 can't handle. The first thing to try is changing the Profile@Level flag. If that doesn't work you'll have to reencode with more xbox 360 friendly settings. -
It says format is MPEG 4. codec id = isom.. format profile = HIGH@L4.1. Please pardon my ignorance...
Yes, it's really an MP4 file. The xbox 360 should be able to play AVC High@L4.1. Maybe the audio codec isn't supported?
It says it's 446kbps at 48khz, 6 channel aac.... the problem maybe?
Yes, 6 channal AAC is probably the problem. Try muxing only the video track into an MP4 file. See if that plays. If so, you know the problem is the audio.
Try to encode H264 to Baseline quality insert High for save.
I use Drag Drop Convert GUI v 1.0.0.1 convert them to H264 Baseline video and AAC audio, it can play even on Xbox 1.0. -
Ok... the 6 channel audio is the issue. Options?
I ran the file through handbrake and it will play now, but the audio is out of sync.(actually seems to go in and out of sync)
Is there a way to strip the audio from the origional file, downmix(or convert) to 2 channel, and re-combine the two files and have them in sync ?
Help Identifying Source
By Charolastra in forum DVD RippingReplies: 8Last Post: 14th Apr 2012, 04:19 -
Can you please help identifying this file ?
By fa355115 in forum Video ConversionReplies: 1Last Post: 23rd Jan 2012, 09:27 -
Identifying OS on DVR HD
By juststarting in forum ComputerReplies: 6Last Post: 24th Feb 2010, 01:29 -
Help identifying this drive
By Noahtuck in forum DVD & Blu-ray WritersReplies: 32Last Post: 20th Feb 2008, 02:19 -
Help identifying drive
By thekfc in forum DVD & Blu-ray WritersReplies: 3Last Post: 14th Jan 2008, 09:28
