Is there a way to get the 35mm equivalent of the zoom range on a camcorder? I try to look avoid looking at the "15x" or "20x" zoom ranges advertized on camcorders and instead look at the mm range. But how do you compare different models and know exactly what the zoom will be like? Does the sensor size make a difference?
Intel i7-950 ASUS GeForce GTX460 1GB 12GB G.Skill DDR3 1600 MHz OCZ Vertex 2 60GB SSD WD Caviar Black 1TB 7200 RPM 64MB Cache
So how do I do the math? Is there a formula of some kind?
Intel i7-950 ASUS GeForce GTX460 1GB 12GB G.Skill DDR3 1600 MHz OCZ Vertex 2 60GB SSD WD Caviar Black 1TB 7200 RPM 64MB Cache -
http://johndudak.com/photographers/fov2.php
You need to know the sensor width/height and the focal length of the lens.
Video techniques - shaking zoom in and zoom out effect?
By Mylo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Oct 2011, 12:08 -
Difference between these two Panasonic camcorder models
By jeanpave in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Jul 2011, 17:11 -
Easycap models and quality?
By liran054 in forum Capturing and VCRReplies: 14Last Post: 14th Feb 2011, 05:19 -
What's the draw for the new 2010 models?
By oldfart13 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Feb 2010, 11:13 -
Sony DCR-SR47 60GB 60 optical zoom camcorder
By newbe tech in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 25th Jan 2010, 20:17
