Hi,
I've just tried about 5 avi/mp4 splitters and any of them doesn't provide good precision of setting split points and fast movie preview.
I've 20hrs of movies that I want to cut and select scenes, but I don't have whole week to do this
The best and the fastest solution for me is software that will provide:
- fast forward and backward rewind to preview movie
- mouse scroll like precision rewind and then setting split point
- re-encoding
- "one-click" save all splitted scenes
Does anyone use/heard about such a soft?
	I feel this is usually the problem with H.264 videos encoded with the AVC codec. All these years, I never had this problem with AVI or WMV files, and used to do my editing with VirtualDub and Cut Assistant almost exclusively. Even videos with the X-Vid codec can be cut from virtually any frame.
 Yes, in H.264 encoded videos like MP4 and MKV, I too haven't found any software that can cut from the "START" marker in precisely the frame i want to.
 So far, the best compromise seems to be AVIDemux. It actually shows the nature of each frame, i.e. I, P or B frame, at the lower portion of the window. As you press the <RIGHT ARROW> or <LEFT ARROW> keys, you can browse each individual frame and find out the nearest I frame, or Keyframe, where you can place the "START" marker for your clip.
 Alternatively, press <UP ARROW> to go the nearest FORWARD Keyframe, or press <DOWN ARROW> to go the nearest BACKWARD Keyframe. This way you can get a clearer idea of where the video clip will start from...
 - Another software I will mention, although I don't know whether it is related with your query, is the H264TS_Cutter. I have used it only once on a TS (transport stream) file containing H.264 video, and I remember it actually cut from a frame that was NOT a keyframe, i.e. pretty precise cut points. However, I don't know if it can be used on files other than TS.
 Thanks...
	finding out the keyframe as suggested by krumm-krumm is admirable. as on today i was searching for a way to find out the i frame so that i can put the start key.thanks
  a good BOB? for DVCPRO via SDI output TO CAPTURE into Precision 690 PC?By cowtowne in forum Capturing and VCRReplies: 0Last Post: 14th Feb 2011, 12:01
  Need a *good* software for converting MP4 to AVI ..By ahmadka in forum Video ConversionReplies: 6Last Post: 24th Nov 2010, 16:44
  Gabest MP4 splitter vs. Haali Media SplitterBy jaduvil in forum Software PlayingReplies: 4Last Post: 16th Jun 2010, 12:57
  Reccommend a good encoder from avi/mkv to mp4By ir0n_ma1den in forum Video ConversionReplies: 2Last Post: 10th Jun 2008, 20:11
  Good Video Splitter?By cucuzza in forum EditingReplies: 4Last Post: 1st Mar 2008, 00:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
