Ok i have this video file that refuse to play in WMP, realplayer etc. It only plays in VLC and MPCHC, in vlc seeking the video makes it blurry for a sec then fine but in MPCHC it plays without a problem. I prefer to keep all my local video show's in my wmp playlist and its pain when i have to search through the folder to play one file in mpchc when it does'nt play on WMP.
I tried installing opencodecs, ffdshow & K-lite codec pack x64 so far without success. Although the container is avi but windows does'nt generate thumbnail of it in explorer neither can virtualdub recognizes it nor AviFix++. I have attached the mediainfo report so please have a look and tell me what i need to play this file in WMP.
Regards,
Sohaib
General
Complete name : H:\PTV Shows\S02EP19. Fiffty Fiffty.AVI
Format : OGG
File size : 1.56 GiB
Duration : 2h 58mn
Overall bit rate : 1 247 Kbps
Video
Format : MPEG-4 Visual
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 2h 58mn
Bit rate : 1 061 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.115
Stream size : 1.32 GiB (85%)
Writing library : DivX 6.8.5 (UTC 2009-08-20)
Audio
Format : Vorbis
Format settings, Floor : 1
Duration : 2h 58mn
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 164 MiB (10%)
Writing library : libVorbis 1.0 (UTC 2002-07-17)
Try make a "real" avi from it with https://www.videohelp.com/tools/OGM_to_AVI
[help] Jump to specific url after playing wmv video file
By techtonik in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2011, 07:23 -
trouble playing this file in WMP in Win XP sp3
By charlieship in forum Newbie / General discussionsReplies: 13Last Post: 26th Jun 2011, 08:10 -
How to play avi/H264 video file on WMP 12
By Tatl in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2010, 19:02 -
WMP 11 can play video file and but produce distorted sound at 48Khz
By hulinning in forum Software PlayingReplies: 1Last Post: 13th Nov 2009, 22:02 -
Playing flv files with WMP
By INFRATOM in forum Software PlayingReplies: 1Last Post: 22nd Jan 2009, 04:12
