I got a MP4 file 1280/720 and instead of showing in AR 16:9, it's showing in 2.35.1 (853:360) from MPC HC...using mp4box.exe -add "P:\T1.mp4" -par 1=1:1 "P:\New.mp4" or mp4box.exe -add "P:\T1.mp4" -par 1=16:9 "P:\New.mp4" doesn't help and using MKVToolnix, VLC and SMPlayer would open correctly @ 16:9 but WMP and MPC-HC wouldn't (still showing in 2.35.1)
Info from MPC-HC
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.08 GiB
Duration : 49mn 56s
Overall bit rate : 3 102 Kbps
Writing application : Lavf53.4.0
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Duration : 49mn 56s
Bit rate : 3 000 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.109
Stream size : 1.05 GiB (97%)
Writing library : x264 core 115
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=2 / weightb=1 / open_gop=0 / weightp=2 / keyint=60 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.41 / aq=1:1.00
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 49mn 56s
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 34.3 MiB (3%)
Language : English
	;/ l ,[____], Its a Jeep thing,
 l---L---o||||||o- you wouldn't understand.
 (.)_) (.)_)-----)_) "Only In A Jeep"
	Thanks for the suggestion! The last time I installed K-Lite was when I was still using XP, but since using Windows 7...no need for K-Lite anymore and not gonna touch anything that associated with K-Lite.
 Jagabo, I tried Yamb and it let me changed the AR to 16:9, but still playing in wrong AR in all players. The only way to play it correctly was to manually use the AR feature in VLC and MPC-HC to set it to 16:9 rather than default, but this is not a good way, as I need to change the AR every time I wanna play this video.
 Anything else I can try?
 Thanks.
	You could try remuxing into MKV instead of MP4. I've never had any problems with AR flags in MKV headers.
  which 'create DVD from MP4" app for Mac that takes any kind of MP4?By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 20:46
  trouble with audio after appending a .jpg turned .mp4 to another .mp4By canadianjameson in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2011, 10:55
  NTSC DV to H264 MP4: Vegas renders wrong aspect ratioBy zigmond in forum EditingReplies: 30Last Post: 16th May 2011, 02:54
  ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 05:53
  MP4 wrong durationBy vsrl2r4 in forum Software PlayingReplies: 0Last Post: 12th Jan 2011, 07:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
