I have a pioneer A03 burner. I have loads of software that I have downloaded from your site and what came with the burner. I have followed all your guides and cant get a good result.
I have managed to get one back up of a dvd to play in part but not in full using nero so i know the media im using and my stand alone dvd player are compatable.
All i want is a easy to follow step by step guide to back up existing dvd's that are under 4.7gb.
Any help would be appreciated
If you had really followed all the guides you would not have any problems anymore, promise. So probably you did not understand everything, so I suggest to read it again carefully. Also use the forum search.
You are speaking the truth.
If you wanted to copy dvd to dvdr which one would you choose.
i will print it out and when i get stuck i will post the problem.
thanx for the quick reply
Codec Newbie Needs Help
By Canyonmaid in forum MacReplies: 8Last Post: 23rd Jun 2011, 19:25 -
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 07:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43
