I have been successfully running Vob2mpg under Bootcamp with Leopard and Snowleopard for several years, but upgrading to Lion and using its new Bootcamp facility has broken Vob2mpg - it just fails to start, with no error message.
I suspect that the partition info might be different with Lion because Lion doesn't 'see' the older Bootcamp partitions.
Anybody out there know if there is a solution?
Regards,
Doug Neale
have you tried uninstalling/reinstalling? any major changes will cause the license check to fail.
Thanks, that fixed it.
I had re-installed but hadn't un-installed first!
Sorry about slow response but lost a hard drive and it had to be drive zero, didn't it!*!*!
Regards,
Doug Neale
problem with VOB2MPG
By Onceler2 in forum Video ConversionReplies: 3Last Post: 16th Sep 2011, 13:12 -
Problem running vob2mpg
By heffneil in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Aug 2010, 10:29 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
vob2mpg problem
By branjk in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Oct 2009, 02:14 -
VOB2MPG Pro Peformance & running multiple version
By Happytobehere2000 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 18th Oct 2009, 08:32
