Hey i get movies off the net and i was wondering how i can get them to play on my dvd , they say they are avi but when i try to burn them to cd , it will not let me i was wondering if these movies are truly an avi file and if so what can i use to get it statred any other info you need please ask and thanks in advance for any replys !!
more less i need to know what program will work ever time i try it it says file not supportted or wont let my burn them to vcd i know i have to convert it to vcd but how ..im sorry im behind the times
corliss :o
no i get the whole proccess i guess just that i dont understand the program i use goes to mpg format then do i burn to vcd ???? for dvd play ???
If your wanting to play an mpg thruough your dvd player you'll have to have a VCD. So you take your output mpg and make it a VCD. HOW? Well Id say for the newbie you should go with VCDImager-GUI http://www.vcdhelp.com/vcdimagergui.htm
All you have to do is take your mpg and load it onto VCDImager, it will then make you a nice bin/cue file which you can now burn with CDRWin.
-Hope this helps
Thanks alot man ... but im trying to go from avi to vcd !!! thanks agian !!
corliss
Why is my sig so big?
By hech54 in forum FeedbackReplies: 1Last Post: 28th Apr 2012, 03:14 -
Big enough pc case?
By A Traveller in forum ComputerReplies: 39Last Post: 21st Aug 2011, 08:37 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
Size is to big
By g_pentium in forum DVD RippingReplies: 9Last Post: 6th May 2008, 04:36 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51
