I think that I did a big no no. I have an Aptek icam, my operating system is windows 7. I plugged the cam into the computer and it wanted to format the disc (cams card), well I said yes, but I changed it to ntfs instead of letting it format fat.......now the icam won't even come on with the card in it, and my computer considers it unrecognizable. I wish that I could get it to recognize again so that I can reformat it back to fat.
I can't believe that I did such a stupid thing.......I am so embarrassed.
The cam works fine as long as I remove the memory card.
Is there a way that I can fix this or do I just have to buy a new card?
Try using Windows' partition management. Right click on My Computer (or Computer), select Manage, Then Storage -> Disk Management in the left pane.
If that doesn't work try Swissknife: http://download.cnet.com/CompuApps-SwissKnife-V3/3000-2248_4-10070864.html -
With the card inside of the icam, when the icam is plugged in now, the computer isn't doing anything.........its as if it's not even plugged in to the usb port.
I tried other ports too
thanks for the suggestion -
Also note that you will need some kind of external card reader since your camera shuts off with the card installed. Do you have a USB card reader that can read your memory card or perhaps a printer that has a card reader built in? Once you have the card plugged into a card reader you should be able to reformat the card using Windows Explorer.
I don't have an external card reader, but maybe I could find someone who does. Thanks
Yes, that's what I meant -- use a card reader so Windows can access the card directly.
MPC-HC upgrade a mistake?
By Monarch1st in forum Software PlayingReplies: 10Last Post: 26th Feb 2012, 14:24 -
Stupid Flanders with his stupid iLoHD04 problems!
By Batchman in forum DVD & Blu-ray RecordersReplies: 33Last Post: 4th Mar 2011, 17:41 -
NERO 9: OMG what a monster!
By jsmithepa in forum ComputerReplies: 16Last Post: 21st Apr 2009, 20:09 -
mistake after burning
By gastzugang in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 15th Sep 2007, 14:43
