I downloaded the movie and subtitle,put them on my usb stick and plug it in,in BD player,everithing works ekcept subtitles,i there any program that can fix this?
Thx![]()
I'd try 3D Subtitler.
If that didn't work, I'd check out poliscript's 3Ditor, or Sony's "ZDepth", CPC MacCaption, ISP S3D title plugin for PP/AE,ELR Studio,...
Maybe use ffdshow's Subtitle renderer (which has auto-2d-to-stereo3d capability and adjustability - but lots of bugs).
If you go down this road, you probably should read this document to understand, and be able to account for, the additional complexities of stereo3d subtitles (depth inversion, window & background violations, scale/size discontinuity).
Make subtitles work with media player classic
By arnie22112000 in forum SubtitleReplies: 27Last Post: 6th Sep 2013, 21:00 -
Blue-Ray DVD Player Philips BDP3100 unlock Subtitles code
By shalevagr in forum Authoring (Blu-ray)Replies: 10Last Post: 19th Jul 2011, 03:50 -
How do I add new subtitles to a existing BLUE RAY
By siopilos in forum SubtitleReplies: 1Last Post: 12th Nov 2009, 10:48 -
is there an option to add subtitles to blue-ray movies ?
By fibola in forum Authoring (Blu-ray)Replies: 1Last Post: 1st Oct 2009, 03:24 -
Ripping/Extracting Subtitles from Blue-Ray
By MounaLafi in forum SubtitleReplies: 3Last Post: 30th Dec 2008, 16:02
