I am trying to use avidemux 2.5.4 (r7200) running on Windows 7 to convert a Windows Media Video file to mp4 (MPEG-4 AVC, AAC (Faac)). When I try to play the converted file using either Windows Media Player or VLC media player, the video is fine but the audio is garbled and unintelligible, lots of hissing and screeching sounds.
This is the file I'm trying to convert:
This is the converted file:Code:General Complete name : C:\Users\John\Desktop\250k.wmv Format : Windows Media File size : 30.2 MiB Duration : 8mn 21s Overall bit rate mode : Constant Overall bit rate : 505 Kbps Maximum Overall bit rate : 510 Kbps Encoded date : UTC 2010-02-22 17:50:06.395 Video ID : 31 Format : VC-1 Format profile : MP@LL Codec ID : WMV3 Codec ID/Info : Windows Media Video 9 Codec ID/Hint : WMV3 Description of the codec : Windows Media Video 9 Duration : 8mn 21s Bit rate mode : Constant Bit rate : 373 Kbps Width : 320 pixels Height : 240 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.194 Stream size : 22.3 MiB (74%) Language : English (US) Audio ID : 1 Format : WMA Format version : Version 2 Codec ID : 161 Codec ID/Info : Windows Media Audio Description of the codec : Windows Media Audio 9.2 - 128 kbps, 44 kHz, stereo (A/V) 1-pass CBR Duration : 8mn 21s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Bit depth : 16 bits Stream size : 7.65 MiB (25%) Language : English (US)
Any idea what I can do to convert this file to MP4 AVC/AAC?Code:General Complete name : C:\Videos\junk2.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 13.3 MiB Duration : 8mn 21s Overall bit rate : 223 Kbps Movie name : junk2.mp4 Writing application : Lavf52.108.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L1.3 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 8mn 21s Bit rate : 112 Kbps Width : 320 pixels Height : 240 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.058 Stream size : 6.66 MiB (50%) Writing library : x264 core 115 r1947 b5a8ad7 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=26.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 8mn 20s Bit rate mode : Variable Bit rate : 106 Kbps Maximum bit rate : 128 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 6.33 MiB (47%)
You could try a ffmpeg frontend like xmedia recode or maybe freemake video converter.
Thanks. I was able to get this to work using avsproxy. It seems that the version of Avidemux that I'm using, 2.5.4 (r7200), does not support decoding of Windows Media Audio files. I tried one file that used WMA 9.2, and when I tried to play it using Avidemux, all I heard was a lot of screeching noise. I then tried playing a file that used WMA 10 Professional. In that case Avidemux said: "No audio decoder found for this file. Save (A+V) will generate bad AVI. Save audio will work".
Trying to convert AVI to MP4 (for iPad) -- Avidemux won't install
By monkeypack in forum Video ConversionReplies: 4Last Post: 28th Nov 2011, 08:18 -
Which is better, AVIDEMUX or HANDBRAKE to convert high quality mkv's to mp4
By rxloren in forum Newbie / General discussionsReplies: 8Last Post: 1st Nov 2010, 20:33 -
Avidemux - DVD/VOB file to MP4/MKV - Audio problem
By prabath_fun in forum Video ConversionReplies: 0Last Post: 7th Sep 2010, 10:32 -
Convert from wmv/asf to mp4 - results in zero length file
By techiejustin in forum ffmpegX general discussionReplies: 1Last Post: 25th Apr 2010, 22:56 -
Avidemux - best quality from wmv to avi/MP4/H264?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 20th Dec 2009, 04:57
