I just ripped a BluRay disc to my hard drive and used tsmuxer to extract the video, audio and subtitle tracks I wanted and then re-muxed them into an mkv with mkvmerge. It worked perfectly, except for the fact that I don't like the position on-screen where the subs are displayed...they are too high up on the screen. From what I've read, the position data is actually encoded into the sub data. Is there any utility out there that can take a .sup file and let me adjust the vertical placement data and re-create the sup file with new position data? I'm not looking to convert to any other format, sup gives me the best display quality (I'm using a WDTV Live plus), I just want the subs to be lower on the screen. (and yes I already checked to see if my player can move them, and it can't).
I don't want to convert them to SUB/IDX. I want to keep them as BluRay subs. I tried using BDsup2sub and the resulting subs looked like crap. All I want is to take an existing SUP file and modify whatever bit holds the vertical position data and reduce that number. Is there anything out there that can do that?
The dopdown that says "Output Format" will allow you to save them as BD sup
Tony -
Well! I don't know what to say to that.
I knew that BDSup2Sub had those settings. I just never tried them. I always just convert to srt because my players will move the SRTs around as well as change the size.
You might try to change the other output possibilities such as framerate and resolution and see if you can get anything to work.
Tony -
I see this is a really old thread, but I tried this on a blu-ray idx/sub and it worked fine.
I exported it in the same format. I haven't tried it with a .sup yet.
Thanks for the tip. I've been looking for a solution to this problem for years.
Demuxing PGS Subtitles
By ematthys in forum SubtitleReplies: 2Last Post: 11th Dec 2009, 14:29 -
Change .ass subtitles size & position when converting
By jadas in forum SubtitleReplies: 2Last Post: 24th Mar 2009, 16:35 -
How to change the subtitle position?How to put it on the top of the screen?
By user2008 in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2009, 07:07 -
Problems with Subtitles Position on screen
By impulse_16 in forum SubtitleReplies: 11Last Post: 27th Oct 2007, 11:06 -
Subtitles : lower position / change color?
By izzat in forum SubtitleReplies: 2Last Post: 25th Aug 2007, 11:21
